Reverse run not working in linuxcnc-plasmac github
- phoenix
29 May 2019 04:27 #135246
by phoenix
Reverse run not working in linuxcnc-plasmac github was created by phoenix
hii Guys ..
i compiled reverse run master on github named linuxcnc-plasmac ] but reverse run function not working in axis or gmoccapy
after pausing program rev and fwd buttons opens but doesnt do anything
do i need to make hal connectons in order for them to function but i dont know whether there is rverse run component in hal or not
- pl7i92
- Thank you received: 358
29 May 2019 06:19 #135249
by pl7i92
Replied by pl7i92 on topic Reverse run not working in linuxcnc-plasmac github
Hi
as Rod saying it is Current not finished
it is experimental and not reedy to use in full Service on a real machine
it will be fixed within some days
- phoenix
29 May 2019 06:26 #135251
by phoenix
Replied by phoenix on topic Reverse run not working in linuxcnc-plasmac github
but in youtube video it seems to work
- Grotius
- Thank you received: 2349
29 May 2019 16:54 - 29 May 2019 16:58 #135298
by Grotius
Replied by Grotius on topic Reverse run not working in linuxcnc-plasmac github
Huh. Where did you get this info?
github.com/grotius-cnc/stable
Above has it all. You only have to copy the plasmac stuff into it and your are master kenobi.
I am waiting about 2 years now. It take's a git programmer about 4- 8 hours. But he programmer needs to stay superfocused at the code !!
But i have done it, so don't worry. And it works, and it is only for professional usage !! It has the latest stable release !!
Last edit: 29 May 2019 16:58 by Grotius.
- Thank you received: 4149
30 May 2019 02:06 #135343
Replied by rodw on topic Reverse run not working in linuxcnc-plasmac github
Picked up from the Developers email group that it is proposed to release the current master branch soon (days not weeks hopefully), then merge reverse run into the new master (call it v 2.9 for now) So give it a bit of time and it should at least be in the main stream.
The following user(s) said Thank You: phoenix
- phoenix
30 May 2019 03:21 #135347
by phoenix
sir do i need to make that again when you update it ??
i ve seen it working on youtube then why it isnt working now
- phoenix
30 May 2019 04:36 #135355
by phoenix
it doesnt have reverse run
i build it and whenever i try to start a configration it says liinux cnc is terminated with an error
30 May 2019 12:45 #135382
2.8 release will be weeks rather than days as we squash the remaining bugs.
But as soon as 2.8 is branched out of master then it will be possibly to merge reverse-run (because, at that point, breaking master is OK again...) and that will be days rather than weeks.
Replied by andypugh on topic Reverse run not working in linuxcnc-plasmac github
- phoenix
02 Jun 2019 03:55 #135609
by phoenix
Is there any way i can make reverse run work...???
- pl7i92
02 Jun 2019 06:56 #135614
by pl7i92
you can fix the errors andy is taking about yourself
best is to wait the remaining 2weeks till the stuff is over the remaining errors you are facing
As i myself need to update around 25 mashines Gantry and wait for the officel release
You can as You got a GIT
daily pull and make it
