Reverse run not working in linuxcnc-plasmac github
- phillc54
- Thank you received: 2100
02 Jun 2019 07:02 #135615
by phillc54
Cheers, Phill.
Replied by phillc54 on topic Reverse run not working in linuxcnc-plasmac github
It works for me in Wheezy, Stretch and LMDE2 for both Axis and Gmoccapy.Is there any way i can make reverse run work...???
Cheers, Phill.
- pl7i92
- Thank you received: 358
02 Jun 2019 08:43 #135619
by pl7i92
Replied by pl7i92 on topic Reverse run not working in linuxcnc-plasmac github
phil is it in your git reprosity
github.com/phillc54/linuxcnc/
- phillc54
02 Jun 2019 09:35 #135623
by phillc54
Reverse run is here:
github.com/phillc54/linuxcnc/tree/reverse-run
Plasmac is here: github.com/phillc54/linuxcnc-plasmac or github.com/phillc54/linuxcnc/tree/plasmac
Cheers, Phill.
Cheers, Phill.
- pl7i92
02 Jun 2019 17:43 #135649
by pl7i92
so its not inside plasmac
only stand alone
only stand alone
- phillc54
02 Jun 2019 23:10 #135672
by phillc54
Yes, it is not part of plasmac, although it is used by plasmac.
Cheers, Phill.
Cheers, Phill.
- phoenix
03 Jun 2019 09:00 #135715
by phoenix
Replied by phoenix on topic Reverse run not working in linuxcnc-plasmac github
sir it seems that paused motion function is not working or I DIIDNT KNOW HOW TO USE IT PROPERLY \
in both cases what can i do to solve this ???
- phillc54
03 Jun 2019 10:30 #135729
by phillc54
You haven't answered my question here
I will try to help you on the above thread when you provide an answer.
Cheers, Phill.
It is not helping that you have the same query going on in three different threads.sir it seems that paused motion function is not working or I DIIDNT KNOW HOW TO USE IT PROPERLY \
Cheers, Phill.
08 Jun 2019 21:59 #136310
Replied by andypugh on topic Reverse run not working in linuxcnc-plasmac github
I just merged Phill's reverse run branch in to master / 2.9
Bhushan: You have to enable adaptive feed (M52) for adaptive feed (including reverse run) to work. Did you do that?
The following user(s) said Thank You: phillc54, chimeno, tommylight, rodw
- Thank you received: 7478
08 Jun 2019 23:48 #136317
Replied by tommylight on topic Reverse run not working in linuxcnc-plasmac github
Fireworks anyone ???
- Thank you received: 4149
09 Jun 2019 00:47 #136323
Congratulations to Phill for all the hard work and thanks to Andy for getting this into master branch.
Andy, thanks for the heads up about M52, probably explains why I could not work out how this works....
Replied by rodw on topic Reverse run not working in linuxcnc-plasmac github
Time to create page: 0.116 seconds
