How to use LinuxCNC to control slave
  • cheng
  • cheng's Avatar Topic Author
  • Senior Member
  • Senior Member
01 Jul 2019 21:26 #138366 by cheng
I have successfully installed igh-ethercat and detected slaves but I don't know how to make the slave station motor turn.
I wish
02 Jul 2019 02:04 #138381 by pl7i92
Replied by pl7i92 on topic How to use LinuxCNC to control slave
hi
you may go with the new MASTER relese
at www.linuxcnc.org/testing-stretch-rtpreempt/
use the ((( 1.3 GB ))) DVD file
linuxcnc-stretch-uspace-amd64-r13.iso
IF YOU ALREDY GOT STRETCH Debian 9 Running use the BUILDBOT to update to master
buildbot.linuxcnc.org/
then follow tutorial
wiki.linuxcnc.org/cgi-bin/wiki.pl?EtherCatDriver
  • Moderator
  • Moderator
02 Jul 2019 12:06 #138417 by tommylight
Replied by tommylight on topic How to use LinuxCNC to control slave
He already has everything installed and running properly.
Now he needs actual commands to test the motors, but i can not help there, maybe Grotius or some other forum member can help.
02 Jul 2019 17:03 - 02 Jul 2019 17:18 #138444 by Grotius
Replied by Grotius on topic How to use LinuxCNC to control slave
Cheng,
First off all welcome to the LinuxCNC forum !
I see you are a new member, living in Hongkong?
You did not use and try any C code example i see wich is provided by Etherlab.
I wish
Do you want to use Linuxcnc to turn your motor?
Or do you want to turn your motor with C or C++ code?
What needs your application?
Haha. So far so good.
pl7i92
He can use .so or .ko kernel insmod's. He don't need a update.
Ethercat works for 32 and 64 bit, just for info.
Last edit: 02 Jul 2019 17:18 by Grotius.
The following user(s) said Thank You: cheng
  • cheng
  • Senior Member
  • Senior Member
02 Jul 2019 19:45 #138478 by cheng
Replied by cheng on topic How to use LinuxCNC to control slave
Thank you very much
  • cheng
  • Senior Member
  • Senior Member
02 Jul 2019 19:46 #138479 by cheng
You are right, I have successfully run, but do not know how to control the motor
  • cheng
  • Senior Member
  • Senior Member
02 Jul 2019 19:58 #138480 by cheng
thanks Grotius .I live in Guangzhou now. Do you know Guangzhou? It is next to Hong Kong. I want to learn how to use LinuxCNC to control the motor. I don't know what to do. Maybe I need to write .hal .xml .ini file.
I am going to find an example of C code in Etherlab.
03 Jul 2019 20:08 #138581 by Grotius
Nice Cheng.
Oke that's fine !
It's important you play a bit in the Etherlab source code. There is one example provided (included) that is basic enough to investegate.
I have a question. Is your system 32 or 64 bit? You can read a bit about .ko and .so kernel modules.
32 bit uses .ko modules. 64 bit uses .so modules.
The installation of 32 bit is quite easy to do. The 64 bit installation is more difficult.
What kind of ethercat slave do you have? Is it a Beckhoff?
  • cheng
  • Senior Member
  • Senior Member
03 Jul 2019 20:20 #138582 by cheng
Thank you. Do you know any other command about LinuxCNC? For example, use
linuxcnc
to open the graphical interface.
I turned on an example from the system, and it worked fine on the PC, but my motor was still quiet.
  • cheng
  • Senior Member
  • Senior Member
03 Jul 2019 20:22 #138583 by cheng
sorry I made a mistake.
Time to create page: 0.173 seconds
