How to use LinuxCNC to control slave
  • cheng
  • cheng's Avatar Topic Author
  • Senior Member
  • Senior Member
01 Aug 2019 19:50 #141162 by cheng
Replied by cheng on topic How to use LinuxCNC to control slave
Hi Cheng,
How is life in your beautifull city?
Relating to your post :
Machine configuration file is 'cpd17_x.ini'
Starting LinuxCNC...
emc/iotask/ioControl.cc 768: can't load tool table. If you add a tool.tbl file and a ini connection you are fertig with this one.
Found file(REL): ./cpd17_x.hal
HAL: ERROR: function 'not.0' not found You have a action to a "not" function somewhere in hal or your component's...
the "not" can be a little line statement somewhere that say's... I will not do this if you do that... So it looks like a if-else function.
www.linuxcnc.org/docs/devel/html/hal/basic-hal.html#_not
the bit inverter function is not found.
./cpd17_x.hal:12: addf failed Here it relates the "not" (bit inverter function) to cpd17_x.hal, line 12...
Shutting down and cleaning up LinuxCNC... Goodbye linuxcnc
LinuxCNC terminated with an error. You can find more information in the log:
/home/mg123/linuxcnc_debug.txt
and
/home/mg123/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
You are going good !
thanks Grotius
I am experiencing tropical storms here. So I saw the impact of bad weather on the city. This is also an alternative life.
I don't know how long it will take to use the LinuxCNC to control the motor, but I will do it when I have time.
  • cheng
  • Senior Member
  • Senior Member
01 Aug 2019 22:15 #141167 by cheng
hi everyone
A new problem arose after I changed the system.
I'm now running a xml ini hal file written by roschi.
error
user@debian:~/examples/ethercat_3axis_CIA402$ linuxcnc basic_3_CIA402.ini
LINUXCNC - 2.7.14
Machine configuration directory is '/home/user/examples/ethercat_3axis_CIA402'
Machine configuration file is 'basic_3_CIA402.ini'
Found file(REL): ./basic_3_CIA402.hal
./basic_3_CIA402.hal:1: lcec_conf exited without becoming ready
Note: Using POSIX realtime
    /home/user/linuxcnc_debug.txt
and
    /home/user/linuxcnc_print.txt
dmesg file
File Name: a.txt
File Size:49 KB
liuxcnc_debug.txt and linuxcnc_printf.txt
File Name: linuxcnc_d...8-01.txt
File Size:0 KB
File Name: linuxcnc_print.txt
File Size:1 KB
ini xml hal file
File Name: basic_3_CI...8-01.ini
File Size:2 KB
File Name: basic_3_CI...8-01.xml
File Size:4 KB
File Name: basic_3_CI...8-01.hal
File Size:1 KB
I think we're pretty close to successfully controlling the motor.
  • cheng
  • Senior Member
  • Senior Member
01 Aug 2019 23:26 #141168 by cheng
The good news.
I successfully used linuxcnc to control the motor.Thanks to everyone, especially Grotius, for their help.
Next, I'm going to control the motor to draw a square. I need to modify it.
cheng
02 Aug 2019 12:58 #141213 by Grotius
Replied by Grotius on topic How to use LinuxCNC to control slave
@Cheng,
Good news....
You are quite quick in writing a new ethercat motor driver.
Important is the next item :
To post your source code over here on the forum, when you are ready.
Motivated like a short how to tutorial, with the type motor drives, the c code, etc. In one zip file would be nice if that fit's to upload.
You are welcome. Maybe one day i could ask you for help...
  • cheng
  • Senior Member
  • Senior Member
03 Aug 2019 00:42 #141252 by cheng
No, the driver code is not what I wrote. The model of the drive I just used is the same as the roschi. I am using the middle code of lece_generic.c.
Still need to ask a question. Now I am using the code for a generic type drive. Next I need to control the motor is it only need to modify the hal file?
03 Aug 2019 14:59 - 03 Aug 2019 15:00 #141294 by Grotius
Hi Cheng,
it's lcec, no lece.
Just be more specefic about the "middle code"
Otherwise give a link to the Roschi code with some explanation. And more info what you exactly mean with "middle code"
If it's a pid, you don't need a very high update time. So in fact you can leave your xml update time quite slow.
The rest you can do in hal. Just as you say my friend.
Last edit: 03 Aug 2019 15:00 by Grotius.
The following user(s) said Thank You: cheng
  • cheng
  • Senior Member
  • Senior Member
04 Aug 2019 19:46 #141380 by cheng
t is my spelling mistake. The correct one should be "lcec_generic". The link to the code I am using.
xml,hal and ini file link .
Thank you. I understand what to do next.
05 Aug 2019 10:36 #141429 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic How to use LinuxCNC to control slave
Use a hex inverter to connect a slave motor
06 Aug 2019 18:46 - 06 Aug 2019 18:50 #141552 by Grotius
Cheng,
The link is not working....
Please post your own working files over here. does not matter if it's not up to date.
We must stay up to date with working config's over here.
Dinuka,
Hmmm.... A motor has no need for a hex connector... Where did you get this info?
forum.arduino.cc/index.php?topic=161783.0
This is for Dinuka to provide more info the next time :
If you say something, please provide info for how and why... Otherwise it looks like crap.
Last edit: 06 Aug 2019 18:50 by Grotius.
  • cheng
  • Senior Member
  • Senior Member
06 Aug 2019 20:04 - 06 Aug 2019 20:18 #141557 by cheng
hi Grotius
Sorry, there's something wrong with the link I provided. I packed the file and uploaded it.
File Name: file.rar
File Size:2 KB
Now it's just passing the servo motor through the slave of the estun. I can only use the left and right arrows on the keyboard.
My description may not be clear. I intercepted a picture to illustrate. After executing "Linuxcnc basic_3_CIA402.ini", I can only control the movement of the motor through the arrow of the keyboard
Next, I want to generate the Gcode, from the picture and drive the motor according to the Gcode.
Can you give me some advice and examples?
For example, what files do I need to modify?
Thanks.
By cheng
Last edit: 06 Aug 2019 20:18 by cheng. Reason: Problem description error
Time to create page: 0.160 seconds
