How to use LinuxCNC to control slave
- cheng
- Thank you received: 9
07 Aug 2019 01:08 #141558
by cheng
"hex"? Yeah, well, maybe my problem is not clear. I'm using the EtherCAT protocol and LinuxCNC. If I'm using a single-chip microcomputer, such as stm32, I need to burn hex.
by cheng
Replied by cheng on topic How to use LinuxCNC to control slave
Use a hex inverter to connect a slave motor
by cheng
- Grotius
- Thank you received: 2349
07 Aug 2019 20:36 - 07 Aug 2019 23:34 #141632
by Grotius
Replied by Grotius on topic How to use LinuxCNC to control slave
@Cheng,
Nice you can move the motor with your key board arrow's.
Left / Right is for x axis
Up / Down if for y axis
In the source code you can change direction of keyboard button's. I have example on stock for that option.
If you make a gcode file like this :
(DxfDecoder version 1.0.0)
(Designed in QT C++, 5.12.3 GCC 64 Bit)
(Provided by Grotius CNC Machines B.V 2019, licence GPL2)
G21 (Metric)
G40 (Cutter compensation off)
G90 (Absolute distance mode)
G64P0.01 (Accuracy 0.01mm of the actual path)
S45
F2500
G00 X0
G00 X100
G01 X0
G01 X100
M30 (it will work if your motor is connected as x axis)
Or for y axis :
G21 (Metric)
S45
F2500
G00 Y0
G00 Y100
G01 Y0
G01 Y100
M30 (it will work if your motor is connected as y axis)
Normally it's a good practice to do this research yourself.
Cheng, please upload the file in previous post in zip format.
Thank you !!
G21 (Metric)
S45
F2500
G00 X0
G00 X100
G01 X0
G01 X100
Or for y axis :
G21 (Metric)
S45
F2500
G00 Y0
G00 Y100
G01 Y0
G01 Y100
Thank you !!
Last edit: 07 Aug 2019 23:34 by Grotius.
- cheng
08 Aug 2019 01:10 - 08 Aug 2019 01:10 #141648
by cheng
Thank you again for your help.
Grotius, thank you for your help. I've never been in contact with machine control before. I majored in electrical engineering and automation in my university. I am now engaged in work related to LinuxCNC,EtherCAT. Therefore, there is a lack of knowledge in this area. I'm working hard. Maybe you can tell me what kind of knowledge I need to master. For example, now I know I should go deep into Gcode.Normally it's a good practice to do this research yourself.
I uploaded compressed files in zip format .Cheng, please upload the file in previous post in zip format.
Last edit: 08 Aug 2019 01:10 by cheng.
- cheng
08 Aug 2019 02:58 #141650
by cheng
Time to create page: 0.190 seconds
