Pointer not jogging on linuxcnc axis ui
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
03 Jul 2019 04:52 #138487 by phoenix
I am trying to set up thc toma on my plasma machine..
Any tips would be appreciated
When i jog machine is jogging but my cone shaped pointer in axis ui is not movinr
Also when i run a gcode only z axis works no x or y motion
Can someone help me?? "
03 Jul 2019 06:35 #138490 by pl7i92
Replied by pl7i92 on topic Pointer not jogging on linuxcnc axis ui
hi
did you setup the ini
with GEMOTRY = XYZ
is there a Startup code in the INI
RS274NGC_STARTUP_CODE = G17 G20 G54 G40 G49 G64 P0.001 G80 G90 G92.1 G94 G97 G98
hard to belive
what system are yo using
2.7 2.8 2.8
and os wheezy mint stretch
  • phoenix
  • Premium Member
  • Premium Member
03 Jul 2019 06:40 #138491 by phoenix
Replied by phoenix on topic Pointer not jogging on linuxcnc axis ui
Hello sir eagerly waiting for your reply ☺
I'm using debian 9 with linuxcnc thc toma
At start it says joint2 on limit switch error so i removed neg and pos components lim from hal
My problem is when i run gcode it stuck at line 3 not moving forward
If i do run from some next line the x and y axes run but thc not working as torch not starts my gcode file has no z axis...
And if i add m3 torch on to the same line the thc works but its not moving to the next line
  • phoenix
  • Premium Member
  • Premium Member
03 Jul 2019 06:41 #138493 by phoenix
Stuck at line 3
I do run from 41 running normally without m3 and torch also not starting
I insert m3 and torch working but xy not moving
Its just do endless probing type something
03 Jul 2019 06:45 #138494 by pl7i92
get
G17 G54
into first line
use
T1 M6
bevore S3400
WHY 3400 that means running on 340 V
i use S112
M3 on separate lines
  • phoenix
  • Premium Member
  • Premium Member
03 Jul 2019 06:54 #138495 by phoenix
I ended up with this error
  • phoenix
  • Premium Member
  • Premium Member
03 Jul 2019 07:00 #138496 by phoenix
Its not moving forward this line
  • Moderator
  • Moderator
03 Jul 2019 09:30 #138503 by tommylight
Replied by tommylight on topic Pointer not jogging on linuxcnc axis ui
ARCOK signal is not wired or has to be set as NOT in hal.
Also you have Z values in that file and very wrong one at that as you have Z-.1f24 ????? How did you get that value? Nevermind, just delete lines with Z values.
THC_toma will not move the machine without a propper ARCOK signal.
S value can be any number.
  • phoenix
  • Premium Member
  • Premium Member
04 Jul 2019 03:15 #138587 by phoenix
Sir will u kindly explain what do you Mean by wrong z values??
  • Moderator
  • Moderator
04 Jul 2019 11:59 #138620 by tommylight
In your gcode you have a value of Z-.1f24
That is not a valid value.
And having 5 threads for the same problem is not helping.
Time to create page: 0.275 seconds
