Pointer not jogging on linuxcnc axis ui
- Thank you received: 4652
05 Jul 2019 12:55 #138682
It will be intered as G1 Z0-0.1 F24
(move to Z -0.1 at a feed rate of 24. That is fine.)
Replied by andypugh on topic Pointer not jogging on linuxcnc axis ui
In your gcode you have a value of Z-.1f24
That is not a valid value.
- Thank you received: 7471
05 Jul 2019 20:35 #138704
Replied by tommylight on topic Pointer not jogging on linuxcnc axis ui
Yup, that is correct Andy. Thank you.
- pl7i92
- Thank you received: 358
06 Jul 2019 08:06 #138724
by pl7i92
Replied by pl7i92 on topic Pointer not jogging on linuxcnc axis ui
you shoudt use
sheetcam free install
to get a good working start
there is a good thc toma postprocessor shiped
and the dxf is realy good processed for plasma
(Created with PLASMA Cutter Radius Compensation post processor 2013/03/17 15:32)
G64 P0.2
(Feeds and Speeds set for machining Please select a material to machine)
G54 (Select Relative Coordinate System)
G17 G90 G21
(tool change to 2 mm PLASMA)
T1 M06
(T)
(M100)
G00 X64.02330 Y432.16019
Z3.800 (pirce Hight)
(G04 P5.5)
S100 M3
M66 P0 L3 Q5 (wait ARC ok)
G01 Z1.500 F500
(G42 D1)
(M101)
G02 X66.71609 Y434.86740 I2.69910 J0.00630 F5000
G01 X110.08170 Y434.98169
X111.26700 Y435.60541
X111.77640 Y435.91318
X435.16080 Y184.58099
X435.02670 Y187.25938
X439.73459 Y187.25938
G02 X442.43457 Y184.55939 I0.00000 J-2.70000
M5
G00 Z30.000
G40
M30
G64 P0.2
G17 G90 G21
T1 M06
(T)
(M100)
(G04 P5.5)
S100 M3
G01 Z1.500 F500
(G42 D1)
(M101)
M5
G00 Z30.000
G40
M30
Time to create page: 0.108 seconds
