Move exceeds joint limit, but joint isn't moved
- Juckix
03 Jul 2019 11:54 #138516
by Juckix
Move exceeds joint limit, but joint isn't moved was created by Juckix
So I'm working with a retrofitted milling machine using Fusion360 for CAM and I'm getting an odd error. There is a short G1 move in X and Y in the middle of the work envelope but when trying to run the program an error is produced saying that the move exceeds the positive limit of joint 2, which is Z. The move can also be run from the same work offset via MDI without issue, and so I'm not sure what the problem could be.
I'm adding screenshots of the setup section of the program as well as the line in question.
03 Jul 2019 13:55 #138529
Replied by andypugh on topic Move exceeds joint limit, but joint isn't moved
What does line 198 say (this is not the same as N198)
I suspect that it is G53 G0 Z0.
What is your joint / axis max limit for Z in the INI?
- Thank you received: 1479
03 Jul 2019 16:15 #138539
Replied by Todd Zuercher on topic Move exceeds joint limit, but joint isn't moved
Also is joint 2 your Z axis or a Y axis slave?
Could you post your ini file?
- Juckix
03 Jul 2019 16:32 #138541
by Juckix
Replied by Juckix on topic Move exceeds joint limit, but joint isn't moved
Line 198 is highlighted in the first screenshot, it's block N990. Positive Z limit is 20. You can find the entire .ini in my response to Todd.
- Juckix
03 Jul 2019 16:33 #138543
by Juckix
Joint 2 is Z. Here you go.
03 Jul 2019 17:57 #138554
I don't see any z moves on line 198 or any of the lines immediately after in your screenshot. Are there any in the 5 or so lines above it?
- Juckix
03 Jul 2019 18:02 #138555
by Juckix
There are not.
03 Jul 2019 18:20 #138557
Any tool changes? Subroutine calls? Remaps?
- Juckix
03 Jul 2019 18:22 #138558
by Juckix
Everything after the setup section you see in the second screenshot is just G1 moves, mostly in X and Y.
03 Jul 2019 18:44 #138560
Curiouser and curiouser. Next could you post a copy of the G-code file. Something's wonky somewhere.
Time to create page: 1.481 seconds
