what is "external offsets"?
03 Jul 2019 17:50 #138551 by chupacabra
what is "external offsets"? was created by chupacabra
What is "external offsets", what is this intended to be used for?
03 Jul 2019 21:21 #138573 by andypugh
Replied by andypugh on topic what is "external offsets"?
It allows you to cause an axis to move by a source external to the G-code commands.
Uses include:
Torch height control on Plasma
Height map comepensation for uneven workpieces based on a probed surface
Lathe axis motion coordinated to spindle angle.
An example of the latter can be seen here:
03 Jul 2019 22:21 #138576 by rodw
Replied by rodw on topic what is "external offsets"?
There are some very cool sims for external offsets that are part of the default installation of V 2.8 and 2.9 if you want to see some ideas on what it could be used for.
I also think Andy's cam grinding idea is very cool
05 Jul 2019 18:30 #138698 by chupacabra
Replied by chupacabra on topic what is "external offsets"?
So if i understand correctly it is like override for position. Thank you!
06 Jul 2019 16:11 #138747 by pl7i92
Replied by pl7i92 on topic what is "external offsets"?
offsets are always position related
external mean they come from numbers not into Gcode
but are called by g-code
like the toolofset G41 G42 comming from tooltable
or basic from the Corrdinate system G54-G59 against the mashine system G53 Tells where to place the part
06 Jul 2019 23:34 - 06 Jul 2019 23:35 #138762 by rodw
This is not correct. You are thinking of tool offsets.
Please refer to the pins starting with axis.N.eoffset on this page
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html
A proportion of the machine's velocity and acceleration are reserved for the external offsets with [AXIS_L]OFFSET_AV_RATIO in your INI file.
when enabled and configured eoffsets work similar to a MPG where a count pin moves the position by a specific distance set by the scale pin. Plasma THC is a special case as external offsets from THC are mutually exclusive with normal motion. So we do a kludge. We use double the possible velocities and acceleration with a Offset Ratio 0f 0.5. This gives us 100% of velocity and acceleration when in normal Gcode mode and also under THC control.
Last edit: 06 Jul 2019 23:35 by rodw.
07 Jul 2019 17:48 #138805 by pl7i92
thank you i dident know that there is somthing like this existing
does plasmac interfear with this offsets as on a pointer view
09 Mar 2021 23:48 #201618 by aluplastvz
Replied by aluplastvz on topic what is "external offsets"?
greeting
Dli with external offsets could compensate for tool wear during polishing of outer edges on a glass polishing machine
thank you
10 Mar 2021 04:16 - 10 Mar 2021 04:16 #201623 by skunkworks
Replied by skunkworks on topic what is "external offsets"?
Another example....
Last edit: 10 Mar 2021 04:16 by skunkworks.
10 Mar 2021 08:21 #201627 by aluplastvz
Thanks for your reply
something like this I need where to find the code
Greeting
