7i80-DB + 7I76 - Example to edit or method to create config
- mjoconr
08 Jul 2019 04:36 #138838
by mjoconr
7i80-DB + 7I76 - Example to edit or method to create config was created by mjoconr
Hi All
I'm looking to create a config for a MESA combination of 7i80-DB + 7I76 with XYZ stepper, touch probe, tool probe, X+Y+Z limits on both directions, 0-10 volt spindle and a spindle encoder.
The encoder might be a single pulse per rev or a proper quadrature 4000 pulse.
I'm looking for help to create this config, I just can not seem to work out how to start the process.
Mike
Mike
- pl7i92
- Thank you received: 358
08 Jul 2019 07:48 #138842
by pl7i92
Replied by pl7i92 on topic 7i80-DB + 7I76 - Example to edit or method to create config
you shoudt have better gone with the 7i96
or the 7i92 +7i76 combination
there are realy many configs on the forum
- mjoconr
08 Jul 2019 09:30 #138849
by mjoconr
Replied by mjoconr on topic 7i80-DB + 7I76 - Example to edit or method to create config
I know that now, but this is what I have. I had planned to use the cards on a different project which was going to need more step and direction ports.
- Thank you received: 5326
08 Jul 2019 13:33 - 08 Jul 2019 13:34 #138860
Replied by PCW on topic 7i80-DB + 7I76 - Example to edit or method to create config
You should be able to use a 7I76E configuration created by pncconf and
just globally change the "7i76e" text in the hal file to "7i80db-16" or "7i80db-25"
Last edit: 08 Jul 2019 13:34 by PCW.
- Thank you received: 7478
08 Jul 2019 13:33 #138861
Replied by tommylight on topic 7i80-DB + 7I76 - Example to edit or method to create config
Use pncconfig to create a config for 5i25/7i76 or 7i76E with the stepgens and I/O you need, then edit it with a text editor to point to 7i80.
Use the "search and replace" function so it takes about 1 minute to edit.
- mjoconr
10 Jul 2019 00:57 #138983
by mjoconr
Does this look correct, I'm not near the machine today and wanted to move forward.
It was generated with the pncconfig and 5i25/7i76
I assume I need something to indicate the ip address of the control board ?
HM-135.ini
HM-135.hal
HM-135.ini
[EMC]
MACHINE = my_LinuxCNC_step
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_step.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.25
MAX_LINEAR_VELOCITY = 22.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1.0
MIN_FERROR = 0.01
MAX_VELOCITY = 22.5
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 28.12
STEPGEN_MAXACCEL = 937.50
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 28.125
# these are in nanoseconds
DIRSETUP = 200
DIRHOLD = 200
STEPLEN = 1000
STEPSPACE = 2000
STEP_SCALE = 500.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 1.0
MIN_FERROR = 0.01
MAX_VELOCITY = 22.5
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 28.125
DIRSETUP = 200
DIRHOLD = 200
STEPLEN = 1000
STEPSPACE = 2000
STEP_SCALE = 500.0
MIN_LIMIT = -0.01
MAX_LIMIT = 150.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1.0
MIN_FERROR = 0.01
MAX_VELOCITY = 16.6666666667
MAX_ACCELERATION = 100.0
STEPGEN_MAXVEL = 20.83
STEPGEN_MAXACCEL = 125.00
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 20.8333333333
DIRSETUP = 200
DIRHOLD = 200
STEPLEN = 1000
STEPSPACE = 2000
STEP_SCALE = 2000.0
MIN_LIMIT = -270.0
MAX_LIMIT = 0.01
HOME_SEARCH_VEL = 1.000000
HOME_LATCH_VEL = 0.500000
HOME_USE_INDEX = NO
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 5000.0
ENCODER_SCALE = 1.0
OUTPUT_SCALE = 10000.0
OUTPUT_MIN_LIMIT = 0.0
OUTPUT_MAX_LIMIT = 5000.0HM-135.hal
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i80db-16.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i80db-16.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i80db-16.0.write servo-thread
# external output signals
# --- ESTOP-OUT ---
net estop-out hm2_7i80db-16.0.7i76.0.0.output-00
# --- COOLANT-MIST ---
net coolant-mist hm2_7i80db-16.0.7i76.0.0.output-01
# --- COOLANT-FLOOD ---
net coolant-flood hm2_7i80db-16.0.7i76.0.0.output-02
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled hm2_7i80db-16.0.7i76.0.0.output-03
# external input signals
# --- BOTH-HOME-Y ---
net both-home-y <= hm2_7i80db-16.0.7i76.0.0.input-04
# --- BOTH-HOME-Z ---
net both-home-z <= hm2_7i80db-16.0.7i76.0.0.input-05
# --- BOTH-HOME-A ---
net both-home-a <= hm2_7i80db-16.0.7i76.0.0.input-06
# --- ESTOP-EXT ---
net estop-ext <= hm2_7i80db-16.0.7i76.0.0.input-08
# --- PROBE-IN ---
net probe-in <= hm2_7i80db-16.0.7i76.0.0.input-09-not
# --- PROBE_IN_UP ---
net Probe_In_Up <= hm2_7i80db-16.0.7i76.0.0.input-10
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i80db-16.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i80db-16.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i80db-16.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i80db-16.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i80db-16.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i80db-16.0.stepgen.00.step_type 0
setp hm2_7i80db-16.0.stepgen.00.control-type 1
setp hm2_7i80db-16.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i80db-16.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_7i80db-16.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i80db-16.0.stepgen.00.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i80db-16.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i80db-16.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i80db-16.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_7i80db-16.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_7i80db-16.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_7i80db-16.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i80db-16.0.stepgen.01.step_type 0
setp hm2_7i80db-16.0.stepgen.01.control-type 1
setp hm2_7i80db-16.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i80db-16.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output <= hm2_7i80db-16.0.stepgen.01.velocity-cmd
net y-pos-fb <= hm2_7i80db-16.0.stepgen.01.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_7i80db-16.0.stepgen.01.enable
net both-home-y => axis.1.home-sw-in
net both-home-y => axis.1.neg-lim-sw-in
net both-home-y => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i80db-16.0.stepgen.02.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i80db-16.0.stepgen.02.dirhold [AXIS_2]DIRHOLD
setp hm2_7i80db-16.0.stepgen.02.steplen [AXIS_2]STEPLEN
setp hm2_7i80db-16.0.stepgen.02.stepspace [AXIS_2]STEPSPACE
setp hm2_7i80db-16.0.stepgen.02.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i80db-16.0.stepgen.02.step_type 0
setp hm2_7i80db-16.0.stepgen.02.control-type 1
setp hm2_7i80db-16.0.stepgen.02.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i80db-16.0.stepgen.02.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output <= hm2_7i80db-16.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i80db-16.0.stepgen.02.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_7i80db-16.0.stepgen.02.enable
net both-home-z => axis.2.home-sw-in
net both-home-z => axis.2.neg-lim-sw-in
net both-home-z => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
setp pid.s.maxerror .0005
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp hm2_7i80db-16.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_7i80db-16.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_7i80db-16.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd-abs => hm2_7i80db-16.0.7i76.0.0.spinout
net machine-is-enabled => hm2_7i80db-16.0.7i76.0.0.spinena
net spindle-ccw => hm2_7i80db-16.0.7i76.0.0.spindir
setp hm2_7i80db-16.0.encoder.00.counter-mode 1
setp hm2_7i80db-16.0.encoder.00.filter 1
setp hm2_7i80db-16.0.encoder.00.index-invert 0
setp hm2_7i80db-16.0.encoder.00.index-mask 0
setp hm2_7i80db-16.0.encoder.00.index-mask-invert 0
setp hm2_7i80db-16.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i80db-16.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_7i80db-16.0.encoder.00.velocity
net spindle-index-enable <=> hm2_7i80db-16.0.encoder.00.index-enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.spindle.gain 60
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
10 Jul 2019 04:25 #138988
You would need to change:
to
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
Assuming you are using the 10.10.10.10 IP address option on the 7I80
Also I think I was wrong on the card name, I think it is always "7i80" regardless of the FPGA size/connector options
to
- mjoconr
11 Jul 2019 01:48 #139044
by mjoconr
Hi All
Still not working but have progress.
So I had to comment out a section for the spindle, I'll need help to get this config adjusted once the other issues are fixed.
But I'm also getting an error 'error finishing read! iter=7'
I wonder if the issue is the firmware in the card (does this need to be loaded each time ?)
Current config below
#setp scale.spindle.gain 60
#setp lowpass.spindle.gain 1.000000
#net spindle-vel-fb-rps => scale.spindle.in
#net spindle-fb-rpm scale.spindle.out => abs.spindle.in
#net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
#net spindle-fb-rpm-abs-filtered lowpass.spindle.outBut I'm also getting an error 'error finishing read! iter=7'
cnc@minimill:~/src/linuxcnc-dev$ linuxcnc ~/linuxcnc/configs/HM-135.ini
LINUXCNC - 2.7.9
Machine configuration directory is '/home/cnc/linuxcnc/configs'
Machine configuration file is 'HM-135.ini'
Starting LinuxCNC...
Found file(REL): ./HM-135.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
iptables v1.6.1: can't initialize iptables table `filter': Permission denied (you must be root)
Perhaps iptables or your kernel needs to be upgraded.
hm2_eth: ERROR: Failed to create iptables chain hm2-eth-rules-outputhm2_eth: WARNING: Unable to restrict other access to the hm2-eth device.
This means that other software using the same network interface can violate
realtime guarantees. See hm2_eth(9) for more information.
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:00:50
hm2_eth: discovered 7I80DB-16
hm2/hm2_7i80.0: Smart Serial Firmware Version 43
Board hm2_7i80.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i80.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i80.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i80.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i80.0: 68 I/O Pins used:
hm2/hm2_7i80.0: IO Pin 000 (J2-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 001 (J2-14): StepGen #0, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 002 (J2-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 003 (J2-15): StepGen #1, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 004 (J2-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 005 (J2-16): StepGen #2, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 006 (J2-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 007 (J2-17): StepGen #3, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 008 (J2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 009 (J2-06): StepGen #4, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 010 (J2-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i80.0: IO Pin 011 (J2-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i80.0: IO Pin 012 (J2-09): IOPort
hm2/hm2_7i80.0: IO Pin 013 (J2-10): IOPort
hm2/hm2_7i80.0: IO Pin 014 (J2-11): Encoder #0, pin Index (Input)
hm2/hm2_7i80.0: IO Pin 015 (J2-12): Encoder #0, pin B (Input)
hm2/hm2_7i80.0: IO Pin 016 (J2-13): Encoder #0, pin A (Input)
hm2/hm2_7i80.0: IO Pin 017 (J3-01): IOPort
hm2/hm2_7i80.0: IO Pin 018 (J3-14): IOPort
hm2/hm2_7i80.0: IO Pin 019 (J3-02): IOPort
hm2/hm2_7i80.0: IO Pin 020 (J3-15): IOPort
hm2/hm2_7i80.0: IO Pin 021 (J3-03): IOPort
hm2/hm2_7i80.0: IO Pin 022 (J3-16): IOPort
hm2/hm2_7i80.0: IO Pin 023 (J3-04): IOPort
hm2/hm2_7i80.0: IO Pin 024 (J3-17): IOPort
hm2/hm2_7i80.0: IO Pin 025 (J3-05): IOPort
hm2/hm2_7i80.0: IO Pin 026 (J3-06): IOPort
hm2/hm2_7i80.0: IO Pin 027 (J3-07): IOPort
hm2/hm2_7i80.0: IO Pin 028 (J3-08): IOPort
hm2/hm2_7i80.0: IO Pin 029 (J3-09): IOPort
hm2/hm2_7i80.0: IO Pin 030 (J3-10): IOPort
hm2/hm2_7i80.0: IO Pin 031 (J3-11): IOPort
hm2/hm2_7i80.0: IO Pin 032 (J3-12): IOPort
hm2/hm2_7i80.0: IO Pin 033 (J3-13): IOPort
hm2/hm2_7i80.0: IO Pin 034 (J4-01): IOPort
hm2/hm2_7i80.0: IO Pin 035 (J4-14): IOPort
hm2/hm2_7i80.0: IO Pin 036 (J4-02): IOPort
hm2/hm2_7i80.0: IO Pin 037 (J4-15): IOPort
hm2/hm2_7i80.0: IO Pin 038 (J4-03): IOPort
hm2/hm2_7i80.0: IO Pin 039 (J4-16): IOPort
hm2/hm2_7i80.0: IO Pin 040 (J4-04): IOPort
hm2/hm2_7i80.0: IO Pin 041 (J4-17): IOPort
hm2/hm2_7i80.0: IO Pin 042 (J4-05): IOPort
hm2/hm2_7i80.0: IO Pin 043 (J4-06): IOPort
hm2/hm2_7i80.0: IO Pin 044 (J4-07): IOPort
hm2/hm2_7i80.0: IO Pin 045 (J4-08): IOPort
hm2/hm2_7i80.0: IO Pin 046 (J4-09): IOPort
hm2/hm2_7i80.0: IO Pin 047 (J4-10): IOPort
hm2/hm2_7i80.0: IO Pin 048 (J4-11): IOPort
hm2/hm2_7i80.0: IO Pin 049 (J4-12): IOPort
hm2/hm2_7i80.0: IO Pin 050 (J4-13): IOPort
hm2/hm2_7i80.0: IO Pin 051 (J5-01): IOPort
hm2/hm2_7i80.0: IO Pin 052 (J5-14): IOPort
hm2/hm2_7i80.0: IO Pin 053 (J5-02): IOPort
hm2/hm2_7i80.0: IO Pin 054 (J5-15): IOPort
hm2/hm2_7i80.0: IO Pin 055 (J5-03): IOPort
hm2/hm2_7i80.0: IO Pin 056 (J5-16): IOPort
hm2/hm2_7i80.0: IO Pin 057 (J5-04): IOPort
hm2/hm2_7i80.0: IO Pin 058 (J5-17): IOPort
hm2/hm2_7i80.0: IO Pin 059 (J5-05): IOPort
hm2/hm2_7i80.0: IO Pin 060 (J5-06): IOPort
hm2/hm2_7i80.0: IO Pin 061 (J5-07): IOPort
hm2/hm2_7i80.0: IO Pin 062 (J5-08): IOPort
hm2/hm2_7i80.0: IO Pin 063 (J5-09): IOPort
hm2/hm2_7i80.0: IO Pin 064 (J5-10): IOPort
hm2/hm2_7i80.0: IO Pin 065 (J5-11): IOPort
hm2/hm2_7i80.0: IO Pin 066 (J5-12): IOPort
hm2/hm2_7i80.0: IO Pin 067 (J5-13): IOPort
hm2/hm2_7i80.0: registered
hm2_eth: ERROR: Failed to execute '/sbin/iptables -A hm2-eth-rules-output -o enp2s0 -p icmp -j DROP'
hm2/hm2_7i80.0: error finishing read! iter=7
loadrt trivkins
loadrt hostmot2
setp hm2_7i80.0.watchdog.timeout_ns 5000000
addf hm2_7i80.0.read servo-thread
addf hm2_7i80.0.write servo-thread
# --- ESTOP-OUT ---
net estop-out hm2_7i80.0.7i76.0.0.output-00
net coolant-mist hm2_7i80.0.7i76.0.0.output-01
net coolant-flood hm2_7i80.0.7i76.0.0.output-02
net machine-is-enabled hm2_7i80.0.7i76.0.0.output-03
net both-home-y <= hm2_7i80.0.7i76.0.0.input-04
net both-home-z <= hm2_7i80.0.7i76.0.0.input-05
net both-home-a <= hm2_7i80.0.7i76.0.0.input-06
# --- ESTOP-EXT ---
net estop-ext <= hm2_7i80.0.7i76.0.0.input-08
# --- PROBE-IN ---
net probe-in <= hm2_7i80.0.7i76.0.0.input-09-not
net Probe_In_Up <= hm2_7i80.0.7i76.0.0.input-10
# AXIS X
setp hm2_7i80.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i80.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i80.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i80.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i80.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i80.0.stepgen.00.step_type 0
setp hm2_7i80.0.stepgen.00.control-type 1
setp hm2_7i80.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i80.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
net x-output <= hm2_7i80.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i80.0.stepgen.00.position-fb
net x-enable => hm2_7i80.0.stepgen.00.enable
# AXIS Y
setp hm2_7i80.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i80.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_7i80.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_7i80.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_7i80.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i80.0.stepgen.01.step_type 0
setp hm2_7i80.0.stepgen.01.control-type 1
setp hm2_7i80.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i80.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-output <= hm2_7i80.0.stepgen.01.velocity-cmd
net y-pos-fb <= hm2_7i80.0.stepgen.01.position-fb
net y-enable => hm2_7i80.0.stepgen.01.enable
# AXIS Z
setp hm2_7i80.0.stepgen.02.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i80.0.stepgen.02.dirhold [AXIS_2]DIRHOLD
setp hm2_7i80.0.stepgen.02.steplen [AXIS_2]STEPLEN
setp hm2_7i80.0.stepgen.02.stepspace [AXIS_2]STEPSPACE
setp hm2_7i80.0.stepgen.02.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i80.0.stepgen.02.step_type 0
setp hm2_7i80.0.stepgen.02.control-type 1
setp hm2_7i80.0.stepgen.02.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i80.0.stepgen.02.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-output <= hm2_7i80.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i80.0.stepgen.02.position-fb
net z-enable => hm2_7i80.0.stepgen.02.enable
# SPINDLE S
setp hm2_7i80.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_7i80.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_7i80.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd-abs => hm2_7i80.0.7i76.0.0.spinout
net machine-is-enabled => hm2_7i80.0.7i76.0.0.spinena
net spindle-ccw => hm2_7i80.0.7i76.0.0.spindir
setp hm2_7i80.0.encoder.00.counter-mode 1
setp hm2_7i80.0.encoder.00.filter 1
setp hm2_7i80.0.encoder.00.index-invert 0
setp hm2_7i80.0.encoder.00.index-mask 0
setp hm2_7i80.0.encoder.00.index-mask-invert 0
setp hm2_7i80.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i80.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_7i80.0.encoder.00.velocity
net spindle-index-enable <=> hm2_7i80.0.encoder.00.index-enable
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-preparedPlease Log in or Create an account to join the conversation.
11 Jul 2019 02:12 #139045
"error finishing read!"
means that you have lost contact with the 7I80
Common reasons are:
Servo thread to fast (suggest 1000000 ns = 1 ms to start)
Not running real time OS
Intel MAC on host and RX IRQ coalesce enabled
Power issues on FPGA card (marginal power so card resets)
Common reasons are:
- mjoconr
11 Jul 2019 02:48 - 11 Jul 2019 02:49 #139047
by mjoconr
Servo thread was 1000000 ns changed to 2000000 ns
Kernel is 4.19.31-rt18
Its using realtek chips for the ethernet, ran ethtool -c rx-usecs=0 enp2s0
Card is being powered by a 5v 5Amp power supply and voltage at the connect on the board is 5.05V
Image of the latency test attached.
What next ?
Thanks by the way
What next ?
Thanks by the way
Last edit: 11 Jul 2019 02:49 by mjoconr.
Time to create page: 0.205 seconds
