7i80-DB + 7I76 - Example to edit or method to create config
- Thank you received: 5314
11 Jul 2019 03:25 - 11 Jul 2019 03:38 #139050
Replied by PCW on topic 7i80-DB + 7I76 - Example to edit or method to create config
What is the ping time?
Also the fact that you get the error so early-on is odd
could you run this command and port the results here:
mesaflash --device ethernet --addr 10.10.10.10 --verbose
Last edit: 11 Jul 2019 03:38 by PCW.
- mjoconr
11 Jul 2019 03:34 #139051
by mjoconr
Replied by mjoconr on topic 7i80-DB + 7I76 - Example to edit or method to create config
ping 10.10.10.10 is 0.309ms +- 0.01 by the looks
11 Jul 2019 03:46 #139052
Can you try the
command and post the result here
- mjoconr
11 Jul 2019 04:05 #139053
by mjoconr
root@minimill:/home/cnc/src/mesaflash# ./mesaflash --device ethernet --addr 10.10.10.10 --verbose
ETH device 7I80DB-16 at ip=10.10.10.10
Communication:
transport layer: ethernet IPv4 UDP
ip address: 10.10.10.10
mac address: 00:60:1B:10:00:50
protocol: LBP16 version 3
Board info:
Flash size: 16Mb (id: 0x14)
Connectors count: 4
Pins per connector: 17
Connectors names: J2 J3 J4 J5
FPGA type: 6slx16ftg256
Number of leds: 4
Board firmware info:
memory spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit) [size=256]
2: EtherEEP (EEPROM, RW, 16-bit) [size=128], page size: 1, erase size: 1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
4: Timers (memory, RW, 16-bit) [size=16]
6: LBP16RW (memory, RW, 16-bit) [size=16]
7: LBP16RO (memory, RO, 16-bit) [size=16]
[space 0] HostMot2
[space 2] Ethernet eeprom:
board name: 7I80DB-16
user leds: eth debug
[space 3] FPGA flash eeprom:
flash size: 16Mb (id: 0x14)
[space 4] timers:
uSTimeStampReg: 0xA477
WaituSReg: 0x0000
HM2Timeout: 0x0000
[space 6] LBP16 control/status:
packets received: all 21032, UDP 20946, bad 0
packets sended: all 13137, UDP 13068, bad 0
parse errors: 0, mem errors 0, write errors 0
error flags: 0x0000
debug LED ptr: 0x0008
scratch: 0x0000
[space 7] LBP16 info:
LBP16 protocol version 3
board firmware version 17
IP address jumpers at boot: fixed from EEPROMPlease Log in or Create an account to join the conversation.
11 Jul 2019 04:11 #139054
OK that's current
Not really sure whats wrong although perhaps the iptables thing is causing trouble
What OS and version of linuxCNC are you running?
how did you install it?
Did you try the Stretch ISO? It should not have the iptables issue
- mjoconr
11 Jul 2019 04:26 #139055
by mjoconr
My issue was that the Wheezy did not support the ethernet chips so I could not use it.
I'll download the ISO and reinstall
There are no iptables rules at this timeNot really sure whats wrong although perhaps the iptables thing is causing trouble
Unbuntu 18.04 using inplace install of (HEAD detached at v2.7.9)What OS and version of linuxCNC are you running?
in-place build of linuxcnchow did you install it?
The 2.7 ISO did not work, when I looked I did not see the Stretch ISO when I did the install during March this year.Did you try the Stretch ISO? It should not have the iptables issue
- mjoconr
11 Jul 2019 06:12 #139066
by mjoconr
So I install the Stretch ISO, the ethernet works and I can start LinuxCNC with out an error.
I assume the issue is the estop / enable in the config.
How do I check if the interface is working when linux CNC is run from the menu ?
- Thank you received: 7465
11 Jul 2019 09:49 #139089
Replied by tommylight on topic 7i80-DB + 7I76 - Example to edit or method to create config
Is the 7i80 wired directly to the PC?
Not through a Hub or Switch !
- mjoconr
11 Jul 2019 09:50 #139090
by mjoconr
Yes, second port on the PC.
Time to create page: 0.573 seconds
