- Thank you received: 9
I don't know if PUMA and PUMA560 have the same geometry and degrees of freedom. But I need to calculate positions for a PUMA with 6 degrees of freedom, because we have an old robot arm with 6 degrees of freedom and it's similar to a PUMA that we'd like to bring back to life.
If I understand the HAL correctly this part of the PUMA HAL seems to be responsible of setting the geometry, but I don't really understand what are those parameters, and I couldn't find any documentation about how these parameters affect the geometry.
I couldn't find any documentation in LInuxCNC about how to set all these parameters for a PUMA to fill out the Denavit-Hartenberg parameters (length of the links, offsets, angles, etc.).
