PUMA geometry
7 years 4 weeks ago #146842 by felixcnc
Replied by felixcnc on topic PUMA geometry
Agreed.
I already have a robot arm, and already have a robot geometry, so in my case I would like to configure LinuxCNC to calculate the joint movements for that particular arm.
I will read what's a "modified DH parameter" but in my case I am just trying to make LinuxCNC to make this arm.
So I was expecting to say "my robot have these DH parameters", but I don't know how to add these parameters to LinuxCNC, and that's what I was asking.
Thanks!
Cheers
7 years 4 weeks ago #146948 by andypugh
Replied by andypugh on topic PUMA geometry
If you look at the Puma560 config files does that help? Presumable there are numbers there that match the sim Puma.
github.com/LinuxCNC/linuxcnc/blob/master...uma560_sim_6.hal#L37
7 years 4 weeks ago #146963 by pl7i92
Replied by pl7i92 on topic PUMA geometry
Hi
lets say it that way
the PUMAKINS is a full defind Construction you need to follow you only got the offsets to be different
pumakins.A2
pumakins.A3
pumakins.D3
pumakins.D4
#####Describe the geometry of the robot#######
in genserkins you got per joint 3 numbers to be set this gives you a variation of the joints to be placed
genserkins.A−N
genserkins.ALPHA−N
genserkins.D−N
de.wikipedia.org/wiki/Denavit-Hartenberg-Transformation
Transformation A
Translatation Alpha
Rotation D
Time to create page: 0.054 seconds
