Beginner question
- Thank you received: 7471
23 Jul 2019 08:28 #140274
Where ??? Last time a checked a month ago, nothing usable under 6800 Euro!
Replied by tommylight on topic Beginner question
therfor most are retrofitting a older MAHO at 1500 USD or simular
- Traktor1Tarzan
23 Jul 2019 13:51 #140290
by Traktor1Tarzan
Replied by Traktor1Tarzan on topic Beginner question
Anything simulare to that in Norway costs around 6000usd, if youre lucky. And its probably really worn down. Which is why im building it, but i also do it for the learning experience.
- Dinuka_Shehan
- Thank you received: 26
23 Jul 2019 15:27 - 23 Jul 2019 15:28 #140297
by Dinuka_Shehan
What are the differences of servo motors and stepper motors.
As well as advantages and disadvantages?
Replied by Dinuka_Shehan on topic Beginner question
For steel i would not recomend steppers, you can get servo drives that use step and direction controll so the wiring is the same, but tuning requires a bit more reading and testing.
Last edit: 23 Jul 2019 15:28 by Dinuka_Shehan.
23 Jul 2019 15:35 #140298
google.com ???
- Dinuka_Shehan
23 Jul 2019 15:48 #140303
by Dinuka_Shehan
really?
google don't give right information always!
23 Jul 2019 16:05 #140307
www.amci.com/industrial-automation-resou...ls/stepper-vs-servo/
www.google.com/search?source=hp&ei=yS83X...K2CYMQ4dUDCAU&uact=5
The first one is short and easy to understand.
- Traktor1Tarzan
23 Jul 2019 17:25 #140320
by Traktor1Tarzan
But back to the question, what kind of controller would you recommend for a 3-axis cnc mill with 5-8A motors?
- Dinuka_Shehan
23 Jul 2019 17:36 - 23 Jul 2019 17:44 #140326
by Dinuka_Shehan
Last edit: 23 Jul 2019 17:44 by Dinuka_Shehan.
23 Jul 2019 17:43 #140329
Sorry, i thought i already replied, must have been another thread.
For step dir type of control (all steppers, new servo drives)
Mesa, for me always as follows
5i25 with 7i76 PCI
6i25 with 7i76 PCI-E
7i92 with 7i76 ethernet
7i96 ethernet (cheapest option, less IO )
7i76E ethernet
All of them offer the same functionality and number of IO, the difference is only in how it communicates with the PC.
For servo systems with analogue control, usually +-10V:
5i25 with 7i77
6i25 with 7i77
7i92M with 7i77 ( M version can be attached directly to 7i77 so no cable needed)
There are other boards and options, with much more IO or other stuff. All of the above have at least another header to control other boards or IO ports or SSERIAL stuff.
Depending on how much you are willing to invest, the main choices there would be 7i92 with 7i77 for servo or 7i76E for steppers. For the price you get very reliable controllers and plenty of IO, expandable to a lot more, and THE best support on planet earth provided by PCW.
If in doubt, just check the "show your stuff" thread on my shop update, i have Mesa boards literally hanging on walls !
5i25 with 7i76 PCI
7i76E ethernet
5i25 with 7i77
6i25 with 7i77
The following user(s) said Thank You: Traktor1Tarzan
- Traktor1Tarzan
23 Jul 2019 19:38 #140346
by Traktor1Tarzan
Thank you! Finally i found someone who gave a clear answer. Ive looked through several forums without finding a clear answer. I really appreciate it.
