Beginner question
- Thank you received: 7471
23 Jul 2019 20:38 #140352
Replied by tommylight on topic Beginner question
You are welcomed, always.
Sorry but i am sure i answered the same question but must have been another thread.
Regards,
Tom.
Regards,
Tom.
- HueyHQ
- Thank you received: 24
24 Jul 2019 00:24 #140369
by HueyHQ
But I think you've answered even better than last time!
Replied by HueyHQ on topic Beginner question
I think you did - I recall reading nearly the exact same answer not long ago. But sometimes finding the post that you know you've seen becomes elusive!Sorry but i am sure i answered the same question but must have been another thread.
24 Jul 2019 01:19 #140378
I am glad ! Still not good at explaining things, but minor improvements.But I think you've answered even better than last time!
- Traktor1Tarzan
24 Jul 2019 05:20 #140396
by Traktor1Tarzan
Replied by Traktor1Tarzan on topic Beginner question
Servos is really the dream, but with 3 servos and the mesa bords it will be between $1150-1720. And with steppers it will be $400
If i buy boards from mesa site, and motor from aliexpress.
Not sure yet which way to go.
- bevins
- Thank you received: 338
24 Jul 2019 18:21 #140449
by bevins
Not really true.
You can get 750Watt ac servos with drives for 170 a set with cables, that's about 500 then 200 mesa go kit, then power supply etc.... 100.
800.00, versus 400 and 10 times better and stronger. Do your self a favor and save up for the servo's. you will regret it if you don't. especially for milling machine.
Just my .314838 cents.
Replied by bevins on topic Beginner question
Not really true.
The following user(s) said Thank You: Traktor1Tarzan
- Thank you received: 1472
24 Jul 2019 19:02 #140456
Replied by Todd Zuercher on topic Beginner question
Also don't forget with steppers you still need a stepper drive between the motor and the Mesa board(s). The price for a cheap Chinese 750w servo from ebay is more like $270.
You could also look at something sort of in between with the new closed loop steppers. A new nema34 motor and drive combo runs around $150.
- Traktor1Tarzan
25 Jul 2019 16:11 #140539
by Traktor1Tarzan
Thanks for the answers. It makes it a lot easier to make good choices.
Are the servos difificult to tune?
25 Jul 2019 16:40 - 25 Jul 2019 16:42 #140544
They can be easy or hard, it depends on a lot of factors. But for the most part tuning a velocity mode servo usually isn't very hard unless there is a problem somewhere. Position mode drives (ones that take step/dir commands like a stepper motor) usually have built in self/auto tuning. (One with only a torque input command are often quite a bit trickier.)
Last edit: 25 Jul 2019 16:42 by Todd Zuercher.
Time to create page: 0.093 seconds
