CNC Sewing machine question
6 years 9 months ago #155021 by andypugh
Replied by andypugh on topic CNC Sewing machine question
Do you need to be able to alter the relative phase?
If not, then a PID controller with feedback from the slave motor position, and command directly from the master motor encoder position will do what you want.
6 years 9 months ago #155023 by ahmetbm
Replied by ahmetbm on topic CNC Sewing machine question
Master encoder will run in velocity control mode, and slave will run in step control mode, i am preparing test setup.
6 years 9 months ago #155028 by andypugh
In PID mode you would need to have the slave run in velocity mode too.
6 years 9 months ago - 6 years 9 months ago #155050 by ahmetbm
I am having trouble with connecting general mechatronics axis dac, can anybody help me by giving instructions?
When i plug gm axis dac, linuxcnc enters estop mode and can not lift up estop button from axis gui, why this may happen?
Last edit: 6 years 9 months ago by ahmetbm.
6 years 9 months ago #155175 by andypugh
This sounds like you might have a wiring fault that is pulling down one of your control voltages.
I have never used General Mechatronics, so this is speculation.
What are you trying to control with the DAC?
6 years 9 months ago #155258 by ahmetbm
andypugh wrote: This sounds like you might have a wiring fault that is pulling down one of your control voltages.
I want to run motor in velocity control mode, So i was thinking the gm axis dac may help.
Time to create page: 3.511 seconds
