Spindle motor start with bob?
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Aug 2019 17:44 #142329 by Dinuka_Shehan
Spindle motor start with bob? was created by Dinuka_Shehan
I want turn on lathe spindle motor with bob!
Using contactor with 3 phase 1.1hp induction motor
In this case I want to turn on and off motor with linux cnc.
Also need to turn on with manual configuration.
Can I use both method?
Is any signal goes to bob if I manually turn on the motor and show spindle motor is running or not?
Thank you
16 Aug 2019 23:00 #142348 by PCW
Replied by PCW on topic Spindle motor start with bob?
Thank you
Some BOBs Like the common "5 Axis Mach BOB" have a relay for this purpose (spindle control)
If your BOB does not have a spindle relay to drive your contactor, you could add a simple SSR
You could use a single BOB input pin connected to a proximity or optical sensor for a simple spindle
speed sensor (with a single or multiple slot wheel on the spindle)
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
17 Aug 2019 15:25 #142391 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Spindle motor start with bob?
My bob have a relay and ordered a 100ppr incremental encoder.
How to turn on spindle motor with linux cnc
17 Aug 2019 16:04 #142396 by PCW
Assuming this is a Parallel port configuration, the stepconf program
can create a hal file with the spindle proper connections, you do need to know
which parallel port pin drives the relay when you run stepconf.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
17 Aug 2019 19:06 #142406 by Dinuka_Shehan
yes
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 08:48 #142930 by Dinuka_Shehan
PCW
where are you>?
23 Aug 2019 21:09 #143014 by PCW
Here of course...
24 Aug 2019 02:57 #143034 by Todd Zuercher
Replied by Todd Zuercher on topic Spindle motor start with bob?
"Here" being somewhere in California (I think, sorry to rat you out Peter.)
24 Aug 2019 03:22 #143038 by rodw
Replied by rodw on topic Spindle motor start with bob?
I really thought Peter lived here on the forum....
24 Aug 2019 07:06 #143059 by Clive S
Replied by Clive S on topic Spindle motor start with bob?
Yes he does I believe he lives in Mesahut B)
