Spindle motor start with bob?
24 Aug 2019 07:48 #143061 by pl7i92
Replied by pl7i92 on topic Spindle motor start with bob?
isent California the Heaven at all
at leased around this days as the GOLDEN season begin
the Elecronics and AI has gone to the World -> Asia
the Brain staying still in non Public areas around California
TRY to visit GOOGLE all you get is a GIANT 3meter Donat with colorfull spatkel's
the Back of a android logo and a image 3D from the Building behind the trees
at apple you see the Front of the Building
at Facebool only the entrance gate HackaDay1
You can Visit FBI MI5 BND even KGB and get a Round tripp
Even somtimes NucPowerplants are up to visit for education
  • Moderator
  • Moderator
24 Aug 2019 09:16 #143072 by tommylight
Replied by tommylight on topic Spindle motor start with bob?
"Here" being somewhere in California (I think, sorry to rat you out Peter.)
I really thought Peter lived here on the forum....
Me 2 ! :)
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Aug 2019 14:57 #143097 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Spindle motor start with bob?
you do need to know
which parallel port pin drives the relay when you run stepconf.
Please stepconf details
24 Aug 2019 16:36 #143100 by PCW
Replied by PCW on topic Spindle motor start with bob?
Have you run stepconf?
Basically in stepconf you can assign functions to each of the parallel port pins
So if say parallel port pin 16 connects to the spindle relay on your BOB
you assign the function "Spindle On" or "Spindle CW" to pin 16 in stepconf
24 Aug 2019 16:37 #143101 by tecno
Replied by tecno on topic Spindle motor start with bob?
You will have to find the PIN on the BOB from it´s documents = pls read!
Then you put that info into stepconf.
24 Aug 2019 16:48 - 24 Aug 2019 16:49 #143102 by Clive S
Replied by Clive S on topic Spindle motor start with bob?
you do need to know
If you are using one of the China cheap bobs with he blue relay on board then pin 17 is used to drive the relay with a jumper setting on the board
Last edit: 24 Aug 2019 16:49 by Clive S.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
25 Aug 2019 14:16 #143144 by Dinuka_Shehan
Stepper motors also not rotating.
Pin 14 enable not wired to stepper driver!
Is it matters?
25 Aug 2019 14:19 #143145 by tecno
Read the manual for the drivers so you know how to setup.
We are not mind readers so we know nothing about your drivers.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
25 Aug 2019 17:11 #143150 by Dinuka_Shehan
X axis
Bob pin 2 pulse
Pin 3 direction
+5V
To stepper driver
Not connect en(enable) to driver
Tb6600 stepper driver
Is enable is required for driver?
25 Aug 2019 17:40 #143152 by tecno
Pls read the relevant TB6600 manual how to connect!
Easier for you to read as you know what version of driver you have.
Time to create page: 0.202 seconds
