Spindle motor start with bob?
- Dinuka_Shehan
- Thank you received: 26
16 Aug 2019 17:44 #142329
by Dinuka_Shehan
Spindle motor start with bob? was created by Dinuka_Shehan
I want turn on lathe spindle motor with bob!
Using contactor with 3 phase 1.1hp induction motor
In this case I want to turn on and off motor with linux cnc.
Also need to turn on with manual configuration.
Can I use both method?
Is any signal goes to bob if I manually turn on the motor and show spindle motor is running or not?
Thank you
Thank you
- Thank you received: 5321
16 Aug 2019 23:00 #142348
Some BOBs Like the common "5 Axis Mach BOB" have a relay for this purpose (spindle control)
If your BOB does not have a spindle relay to drive your contactor, you could add a simple SSR
You could use a single BOB input pin connected to a proximity or optical sensor for a simple spindle
speed sensor (with a single or multiple slot wheel on the spindle)
Replied by PCW on topic Spindle motor start with bob?
Thank you
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
17 Aug 2019 15:25 #142391
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Spindle motor start with bob?
My bob have a relay and ordered a 100ppr incremental encoder.
How to turn on spindle motor with linux cnc
17 Aug 2019 16:04 #142396
Assuming this is a Parallel port configuration, the stepconf program
can create a hal file with the spindle proper connections, you do need to know
which parallel port pin drives the relay when you run stepconf.
- Dinuka_Shehan
17 Aug 2019 19:06 #142406
by Dinuka_Shehan
yes
- Dinuka_Shehan
23 Aug 2019 08:48 #142930
by Dinuka_Shehan
PCW
where are you>?
where are you>?
23 Aug 2019 21:09 #143014
Here of course...
- Thank you received: 1472
24 Aug 2019 02:57 #143034
Replied by Todd Zuercher on topic Spindle motor start with bob?
"Here" being somewhere in California (I think, sorry to rat you out Peter.)
- Thank you received: 4144
24 Aug 2019 03:22 #143038
I really thought Peter lived here on the forum....
Replied by rodw on topic Spindle motor start with bob?
- Clive S
- Thank you received: 486
24 Aug 2019 07:06 #143059
by Clive S
Replied by Clive S on topic Spindle motor start with bob?
Yes he does I believe he lives in Mesahut
Time to create page: 0.383 seconds
