Please help! Joe's 2006 CNC
27 Aug 2019 23:26 #143371
I had a set of 8-wire steppers where the _actual_ wire colours did not match the data sheet in the box that the steppers came in!
You need to work out which pairs of wires are each end of a phase, then which phases are pairs, and which direction is which.
You can do all this without even a multimeter.
1) Find which wires are each end of a winding. You can do this with a multimeter, or try touching together every combination one by one (making sure that only two are connected at a time). Whedn two ends of a winding are connected then the motor will be hard to turn.
Label these as A, B, C, D.
2) Now connect one end of A to one end of B, and connect the other end of A to the other end of B. If the motor is very stiff to turn then A+ is connected to B- and A- to B+. If it is easy to turn, then it might be A+ to B+ and A- to B-, so swap them. If the motor still turns freely, then try A and C as a pair, and then A and D.
3) The unpaired windings must be the other pair, work out the polarity the same way.
You now know which windings are pairs, and which end of each is + and -.
Replied by andypugh on topic Please help! Joe's 2006 CNC
There are a whole lot of ways to wire an 8 lead step motor wrong for a uni-polar drive. Be sure you did it right.
- NW T1mber Art
28 Aug 2019 01:23 #143383
by NW T1mber Art
Replied by NW T1mber Art on topic Please help! Joe's 2006 CNC
To everyone who has commented and tried to help, thank you! My issues are now resolved and my CNC is in working order once agian. My pin settings were all incorrect and the lead screw pitch was wrong. Now that I have learned the internal workings of the software I shouldn't have any problems. Agian, thank you to everybody who has invested their time to try and help me.
