First time CNC builder here... need advice.
- Agawa
26 Aug 2019 09:20 #143222
by Agawa
First time CNC builder here... need advice. was created by Agawa
Hello everyone.
This may seem like a very newbie post here but I am very interested in building my first CNC machine... My current occupation is an Industrial Electrician at a steel mill so the electronic part of the machine is very clear to me.. My only question is for what controller set up to go with.. Ive spent hours reading up on Arduino...grbl... different type of break out boards... mach 3..fusion 360 etc... I think i have now made the choice to go the Linux CNC route... I am also interested in communicating by ethernet. Just wondering if anyone could steer me into the right direction for a Linux CNC set up and also opinions from some veterans out there. I want to start out with a Z Y X axis router configuration but eventually turn it into a plasma set up. My frame would be constructed from steel along with linear rails with bearing blocks... So my main question is... Is there a good recommended breakout board that linux cnc can communicate via ethernet? i want to avoid parallel ports...
- Thank you received: 7509
26 Aug 2019 10:00 #143223
Replied by tommylight on topic First time CNC builder here... need advice.
If you plan to use steppers, your best choice will be the Mesa 7i96, or if you can afford it get the 7i76E.
- Agawa
26 Aug 2019 10:05 #143224
by Agawa
Replied by Agawa on topic First time CNC builder here... need advice.
okay thank you. yes steppers for the first machine. Nema 23's...
also..would a PCI > Parallel port adapter work since my MOBO doesnt have a parallel port?
- Clive S
- Thank you received: 486
26 Aug 2019 10:23 - 26 Aug 2019 10:23 #143226
by Clive S
The 7i76e is connected by Ethernet to the pc a cheaper version is the 7i96 also Ethernet .
If you want to go with the 7i76 it is generall connected to the pc with a 5i25 or 6i25 depending on pci or pcie
Replied by Clive S on topic First time CNC builder here... need advice.
Last edit: 26 Aug 2019 10:23 by Clive S.
26 Aug 2019 10:36 #143229
Yes a PCI to parallel card will work, but there are some that do not. I used a lot of them made by NetMos or MosChip.
- Agawa
26 Aug 2019 12:33 #143234
by Agawa
okay so i may have jumped the gun here...since this will be my very first build i think im going to stick with a PARALLEL B.O.B.and try go with a PCI to Parallel adapter card...
I am going to go with a Sainsmart 5 AXIS ST-V6 board. It is fairly cheap and should be good for my self learning experience.
For my PCI adapter card I will be going with a MOSCHIP parallel card...
next on my list is to go with 4 seperate driver boards, or is there one unit driver board that someone can suggest?
this definately has been a huge learning curve for me and I thank everyone who is helping me out!
- Thank you received: 1483
26 Aug 2019 13:01 #143236
Replied by Todd Zuercher on topic First time CNC builder here... need advice.
If you have to buy a parallel port card anyway, I'd strongly consider going straight to a Mesa 5i25(PCI card) or 7i92(Ethernet version of the same) to use with your parallel port breakout board, they only cost $89.
Also look your motherboard over carefully, a lot of them still might have a 26-pin header for attaching a parallel port if they don't have an actual parallel port. My work computer does (Lenovo), and it was never advertised as having a parallel port.
The following user(s) said Thank You: Agawa
26 Aug 2019 13:14 #143238
You can start with TB6600 drives, they are around 50$ for 4 of them.
- Agawa
26 Aug 2019 13:19 #143240
by Agawa
Yes i just checked one of my old AM3 MOBO and it does infact have a LPT header. I would just need a ribbin cable if that. thank you again!
- pl7i92
- Thank you received: 359
26 Aug 2019 13:29 #143241
by pl7i92
Replied by pl7i92 on topic First time CNC builder here... need advice.
i got a full advice as a video here
Time to create page: 0.120 seconds
