First time CNC builder here... need advice.
26 Aug 2019 19:36 #143264 by Leon82
Replied by Leon82 on topic First time CNC builder here... need advice.
The gecko g540 is an option also
26 Aug 2019 19:37 #143266 by Leon82
Yes i just checked one of my old AM3 MOBO and it does infact have a LPT header. I would just need a ribbin cable if that. thank you again!
I got one off Amazon for mine. It was 6$
26 Aug 2019 20:47 #143269 by Agawa
I just ordered 4 tb6600 drivers from Amazon. Was way cheaper than the gecko 540. Thank you for all the quick replys!
28 Aug 2019 18:52 - 28 Aug 2019 18:53 #143508 by Agawa
Okay so all my parts should be here tmrrw. I'm hoping just to set up a test bench and then jogging the motors from software and what not. My next question is. What is a great CAM software to get familiar with? I have some experience with AutoCAD from my college days is there any software out there that can use .dwg files to convert them to G code?
Last edit: 28 Aug 2019 18:53 by Agawa.
  • Moderator
  • Moderator
29 Aug 2019 03:14 #143536 by tommylight
Replied by tommylight on topic First time CNC builder here... need advice.
Fusion360 from Autodesk, it should be free for students and stuff. I never used it.
29 Aug 2019 14:43 #143593 by Leon82
Fusion is free under a startup licence, it's cloud based.
It has parametric modelling and can make tool paths
30 Aug 2019 02:21 #143637 by rodw
Also look at onshape. its really cloud based and free if you share your work as open source. You can even use it on your phone!
