SOS-Config ruined after dist-up. Back to previous version old LinuxCNC dist?
20 Sep 2019 11:23 - 20 Sep 2019 12:03 #145658 by m.bofi
To my horror today as i returned to check my configuration i realised that something goes terribly wrong. First as i open AXIS 4 errors pop up:
STEPGEN: Channel 1: The requested maximum velocity of 1252 step/sec is too high
STEPGEN: The maximum possible frequency is 1250 steps/second
and the same 2 for channel 2.
Secondly i jogged the five joints. Two of them work just fine. However the other 3 are messed up. Specifically, both + and - buttons used for jogging, move the joint to the same direction.
From what I'm told the only thing that changed since yesterday that all were fine is that this morning they "apt-get update" and "apt-get dist-upgrade". The dist-upgrade did the 3 availables upgrades to linuxcnc, linuxcnc-doc and a third (which they didn't remember). But can a dist change so drammatically that reads the same information as the previous one but interpets them differently?
From what i see the configuration files are intact(hal, ini, etc), but the result is catastrophe. Is there a way to roll back to the version i was? Can anything be done to check what changed?
Last edit: 20 Sep 2019 12:03 by m.bofi.
20 Sep 2019 12:23 #145666 by andypugh
First of all, what does "uname -a" say? Just to make sure that the updates have not over-written the realtime kernel.
20 Sep 2019 12:24 #145667 by m.bofi
Linux X004 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
20 Sep 2019 12:28 #145668 by andypugh
OK, so that part seems OK.
Which version of LinuxCNC were you running before? Which version is it running now?
20 Sep 2019 12:31 - 20 Sep 2019 13:24 #145669 by m.bofi
Now its the 2.9.0-pre0-653-gb25997c. The previous i'm not sure :( The previous official branch is v2.9.0-pre0-645-g0742250 right? ( source ) So that's probably it? Actually i haven't had and upgrade for a week so im not quite sure
Last edit: 20 Sep 2019 13:24 by m.bofi.
20 Sep 2019 14:43 #145675 by andypugh
Were you always running a version of master? No chance that you were previously running 2.7?
20 Sep 2019 15:10 #145681 by m.bofi
For the past 4 months definitely master because I wanted the Joint-Axes changes. Before that I had 2.7.14. However the change has been done several months now and the configuration was stable
20 Sep 2019 15:18 #145682 by andypugh
OK, that seems very strange.
If you are updating via Synaptic then you can (somehow, I have forgotten how, but I have done it) force the system back to a previous version.
Are you sure that you are starting the configuration that you think you are? How are you starting the config?
20 Sep 2019 15:23 - 20 Sep 2019 15:25 #145683 by m.bofi
The update happened through terminal with dist-upgrade. Can it be undone with synaptic manger then? Even to a little older stable version, for example two weeks ago?
Yes it's the same config. Actually the only config I have set on that pc. I start LinuxCNC and pick the config. Nothing special actually. That's why I'm so panicked. It seems very strange to me too.
Last edit: 20 Sep 2019 15:25 by m.bofi.
20 Sep 2019 15:25 #145684 by andypugh
Yes, apt and Synaptic use the same database.
You can step back a level with apt too...
askubuntu.com/questions/138284/how-to-do...-package-via-apt-get
Time to create page: 0.522 seconds
