SOS-Config ruined after dist-up. Back to previous version old LinuxCNC dist?
20 Sep 2019 15:34 - 20 Sep 2019 15:41 #145686 by m.bofi
How does this apply to LinuxCNC versions though? Apt-get install LinuxCNC=<official release I want>?
And isnt it necessary that this prev version exist in a repository. From what I know only the latest versions are in the LinuxCNC repository. Latest 2.7.14 or latest 2.9.0(master)
Last edit: 20 Sep 2019 15:41 by m.bofi.
20 Sep 2019 15:45 #145688 by andypugh
That link had a way to list the available versions. Does that say anything useful?
20 Sep 2019 17:14 #145692 by m.bofi
Unfortunately i dont have access to the specific pc now until Monday. I will try to check the general idea behind it with virtual machine on virtualbox.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
20 Sep 2019 17:39 #145694 by Todd Zuercher
Yes it is, and there are some there, for example right now buildbot has for Master from 2.9.0~pre0.653 back to 2.9.0~pre0.556.
2.7 is the current stable release of LInuxcnc. 2.9 (Master) is the current development branch (not stable). 2.8 is on the cusp of being released as the latest stable release of Linuxcnc. You can install it using the Linuxcnc repositories on buildbot.linuxcnc.org/ To install 2.8 simply setup a repo exactly the same as your buildbot repo for 2.7, except changing 2.7 to 2.8. The repos are there for 2.8, just the web pages and docs have not been updated to point to it yet because it's release isn't "official" yet.
23 Sep 2019 09:00 #145935 by m.bofi
I found the way to downgrade and i have been testing every past linuxcnc ver. However none works. And from a photo i had saved i verified that previously i had 2.9.0-pre0-613 and the config worked just fine. But now that i check the same version and it doesnt work. I am so buffled. What could cause this?
23 Sep 2019 09:07 #145936 by andypugh
Can you post the HAL and INI files here?
I wonder if this might be a hardware failure.?
23 Sep 2019 09:19 #145937 by m.bofi
I am very positive that hardware works quite well. But then again maybe electronics is to blame and i cant really check this possibility. A bit of information about the config. Its a Mitsubishi RM501, a serial robot with 5 rotational joints with a custom controller, made by a previous student. The last two joints(the wrist) are linked with a differential system. when both motors rotate the same way the wrist goes up or down. When the motors turn in different directions the wrist rotates.
23 Sep 2019 12:02 #145947 by andypugh
# This config file was created 2019-06-12 17:17:26.311120 by the update_ini script
I assume that it was all working fine between 2019-06-12 and 2019-09-20 when you posted the first message?
Looking at the HAL (which is quite complicated) prompted some memories. Is this the same robot?
forum.linuxcnc.org/27-driver-boards/2759...ifiers?start=0#44662
The posts there do at least explain how the HAL is intended to function.
Step scale is 40 steps/degree and STEPGEN_MAXVEL (commented out in Joint 0) is 31.3. That means that you are, indeed, asking for 1252 step/second. The stepgen rate warning seems like it should always have been there, with a base period of 40,000nS.
Setting the STEPGEN_MAXACCEL to 31.2 (and uncommenting Joint0) will quiet that message.
Which joints are working, and which ones not? Can you check that the stepper drive direction pins are changing state as you attempt to jog in each direction?
23 Sep 2019 12:18 #145949 by m.bofi
Indeed it is! And yes after some minor adjustments to the ini and the custom kinematics it worked fine. Especially during last week that i ran some tests all was fine.
Joint 0 and joint 2 work as they supposed to.The problem with joint 1 and the wrist(joint 3 and 4).
im quite bad at this. how do i check it?
23 Sep 2019 14:57 - 23 Sep 2019 14:59 #145968 by m.bofi
I tried almost all 2.8 ver available on buildbot as well as the 2.7.14 as well and the problem insists.
So i just connected the old pc which had the original config with a 2.7.14-112 ver and it appears all works fine, apart from the fact that is is exceptionally slow(one of the reasons i went ahead and the config to a new pc). However the good news is that since it works fine we can verify that it is not a hardware malfunction, right?
And now i'm very very curious what has happened to the new pc and it doesnt work.
Last edit: 23 Sep 2019 14:59 by m.bofi.
Time to create page: 0.144 seconds
