Where is a screenshot stored? ***SOLVED***
27 Sep 2019 06:47 - 29 Sep 2019 02:56 #146334 by Scot
Hello, all..
So I'm trying to find a screenshot that I took to show the output of Halscope. <yes, I got it to work>
Might anyone know off hand where I can find that image?
Scot
Last edit: 29 Sep 2019 02:56 by Scot.
27 Sep 2019 06:51 #146336 by pl7i92
Replied by pl7i92 on topic Where is a screenshot stored?
in folder images
what system are you on stretch Debian
27 Sep 2019 06:59 #146340 by Scot
Replied by Scot on topic Where is a screenshot stored?
I'm using 2.7.14 debian 9.
27 Sep 2019 07:05 #146342 by pl7i92
ok
so i guess you use xfce for shooting
wiki.debian.org/ScreenShots
the image shoudt be as you took it from terminal in the same folder so i guess in maybe in linuxcnc as you have been there for editing
The following user(s) said Thank You: Scot
27 Sep 2019 07:12 #146345 by Scot
Sincerely appreciated.
  • Moderator
  • Moderator
27 Sep 2019 09:36 #146355 by tommylight
Replied by tommylight on topic Where is a screenshot stored?
Linix Mint saves them on Desktop, did you check there ?
27 Sep 2019 11:00 #146365 by pl7i92
please mark the Tread as closed and solved it is working for you
27 Sep 2019 17:38 #146416 by Scot
Not there. I've checked high and low, even in gimp. But I can't seem to find it. I actually don't even know if it was captured. Nothing came up when I pressed alt PrintScrn or just PrintScrn by itself.
Linux isn't new to me, but I'm not seriously versed in it. So since I haven't used it since Redhat 7.3, I have no idea what's missing from my configuration, nor do I have much in the department of knowledge to make things work if and when parts of the configuration are missing, which they often are, if not hidden from the less-versed. If it makes any difference, I'm using an out of the box, unchanged LinuxCNC 2.7.14.
I love the way it works, unfortunately, I don't quite know enough about how to make it work when there are parts not working. It's never been super user friendly.
The Debian directions say to press alt PrintScrn or just PrintScrn by itself. But as I said, nothing happens and no files show up in my home directory or in a place I can see in gimp, or any place I can see.
What I'm trying to do is capture a screenshot and post it here and send it to Jon Elson to see if I can figure out the tuning of a single brushless servo.
I'm kind of a newbie to much of this, but I also understand enough to get me into trouble.
Thanks for the heads up, though.
27 Sep 2019 17:38 #146417 by Scot
It isn't solved.
27 Sep 2019 17:52 #146421 by Scot
Solved!
Applications >Accessories>Screenshots
Easy gui, too! Man I should probably take more time to sleep on things.
Scot
Time to create page: 0.101 seconds
