5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
- Tavares
17 Oct 2019 17:34 #148132
by Tavares
5i25-7i76 Kit vs 7i76E which one should i buy? HELP! was created by Tavares
Good morning, I am building a 3 axis router with hybrid motors, I am looking for controllers and I came across the kit 5i25-7i76 that seems to be easier to setup, also saw 7i76E for the same price all in one ethernet card, which do you recommend? Is 7i76e easy to set up? Does the linuxcnc wizard configurator work on this board?
- Thank you received: 7468
17 Oct 2019 17:59 #148135
Replied by tommylight on topic 5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
There is a 7i96 that is cheaper and has everything you need and more, ethernet only.
- Thank you received: 1472
17 Oct 2019 18:01 #148136
Replied by Todd Zuercher on topic 5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
Another Ethernet option to consider is the 7i96.
I would say the Eithernet options are a little trickier to set up. Because you have to properly configure the network cards in Linux to make sure that Linux doesn't try to use the one used for Linuxcnc for anything else.
- Tavares
18 Oct 2019 05:11 #148163
by Tavares
Replied by Tavares on topic 5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
i found some tutorials how to config 7i76E, i think its pretty easy
video
7i76e i can use wizard, but i couldnt find 7i96. There is some tutorial?
- Tavares
18 Oct 2019 05:16 #148164
by Tavares
i forgot to say, 7i96 has two version, 5 Stepgens and 4 Stepgens 1 PWM, pwm? to control spindle?
- Clive S
- Thank you received: 486
18 Oct 2019 07:07 #148166
by Clive S
See here:- forum.linuxcnc.org/27-driver-boards/3504...6-configuration-tool
Replied by Clive S on topic 5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
- Tavares
19 Oct 2019 19:44 #148355
by Tavares
iam almost buying 7i76e, but this board will work with pentium 4 3.0ghz 1gb ram?
- pl7i92
- Thank you received: 358
19 Oct 2019 19:55 #148358
by pl7i92
Replied by pl7i92 on topic 5i25-7i76 Kit vs 7i76E which one should i buy? HELP!
Time to create page: 0.199 seconds
