7i96 Can't get PWM output - SOLVED
  • jools
  • jools's Avatar Topic Author
  • Elite Member
  • Elite Member
21 Nov 2019 16:03 #150841 by jools
Replied by jools on topic 7i96 Can't get PWM output - SOLVED
The signal names can be listed via halcmd so there is no need to guess
in fact you can list all signal, pins, and parameters and create a file for
copy pasting with
halcmd show all > allnames.txt
I put the commands in the main hal file
Had to delete the entries that the configuration tool had put in the io.hal file and it works.
Thanks so much. :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss: :kiss:
Jools
p.s This should maybe be made a sticky.
10 Jan 2021 13:54 #194724 by BigJohnT
Replied by BigJohnT on topic 7i96 Can't get PWM output - SOLVED
I do believe I've corrected all the issues with the 7i96 Configuration Tool and in addition added the ability to flash the following
5 StepGens , 7i96d.bit
4 StepGens 1 PWM, 7i96d_1pwm.bit
7i96 + 5abob, 7i96_5abob.bit
7i96 + 6 Encoders, 7i96_6enc_d.bit
7i96 + 7i76, 7i96_7i76d.bit
7i96 + 7i77, 7i96_7i77d.bit
7i96 + 7i78, 7i96_7i78d.bit
7i96 + 7i85, 7i96_7i85d.bit
7i96 + 7i85S, 7i96_7i85sd.bit
7i96 + 7i89, 7i96_7i89d.bit'
7i96 + G540, '7i96_g540dpl.bit
JT
