Control driver's power through linuxcnc
- Thank you received: 4151
24 Nov 2019 12:32 - 24 Nov 2019 12:41 #151103
Replied by rodw on topic Control driver's power through linuxcnc
I had a bit of a look at the halui pins and I did not see one that leapt out at me but you could achieve it with estop-latch.
Its not well documented but it is designed to build an estop chain in software.
As my machine grew, I added more estops so moved them all to estop-latches chained together. One of them was for a plasma torch breakaway which triggered an e-stop so that is functionally equivalent to what you want. You can trigger a relay from one of the e-stop outputs. Here is a complex example from my config. You can see I turn a few things on and off with the estop-out signal.(relays and warning lights)
Warning: Spoiler!
# --- ESTOP CHAIN STARTS ---
net latch-reset <= iocontrol.0.user-request-enable
net latch-ok-in <= iocontrol.0.user-enable-out
net latch-ok-in => estop-latch.0.ok-in
net latch0-out <= estop-latch.0.ok-out
net latch0-out => estop-latch.1.ok-in
net latch1-out <= estop-latch.1.ok-out
net latch1-out => estop-latch.2.ok-in
net latch2-out <= estop-latch.2.ok-out
net latch2-out => estop-latch.3.ok-in
#net latch3-out <= estop-latch.3.ok-out
#net latch3-out => estop-latch.2.ok-in
net latch-reset => estop-latch.0.reset
net latch-reset => estop-latch.1.reset
net latch-reset => estop-latch.2.reset
net latch-reset => estop-latch.3.reset
net latch-out iocontrol.0.emc-enable-in <= estop-latch.3.ok-out
net estop-out estop-latch.3.fault-out
# --- EXTERNAL ESTOP SWITCH - CONTROL BOX---
net external-estop <= hm2_7i76e.0.7i76.0.0.input-00
net external-estop => estop-latch.0.fault-in
# --- EXTERNAL ESTOP SWITCH - CONSOLE ---
net console-estop <= hm2_7i76e.0.7i76.0.0.input-31-not
net console-estop => estop-latch.3.fault-in
# --- PENDANT ESTOP SWITCH ---
net pendant-estop <= hm2_7i76e.0.7i76.0.0.input-26-not
net pendant-estop => estop-latch.1.fault-in
# --- TORCH BREAKAWAY E-STOP ---
net torch-breakaway <= hm2_7i76e.0.7i76.0.0.input-06
net torch-breakaway => estop-latch.2.fault-in
# --- E-STOP STEPPER DRIVE DISABLE ---
net estop-out hm2_7i76e.0.7i76.0.0.output-05
# --- E-STOP RED WARNING LIGHT ---
net estop-out hm2_7i76e.0.7i76.0.0.output-00
net estop-out hm2_7i76e.0.7i76.0.0.output-10
# --- ESTOP CHAIN ENDS ---
Last edit: 24 Nov 2019 12:41 by rodw.
- Muz94
24 Nov 2019 12:49 #151105
by Muz94
Replied by Muz94 on topic Control driver's power through linuxcnc
However, just to be clear, i'm going to switch to a 7i96 sooner than later, so i would not focus on the charge pump, i'd rather prepare a good schematic and then implement the whole estop circuit when i'll install the mesa board.
- Muz94
24 Nov 2019 12:50 #151106
by Muz94
Thank you, i'll look into this!
Warning: Spoiler!# --- ESTOP CHAIN STARTS --- net latch-reset <= iocontrol.0.user-request-enable net latch-ok-in <= iocontrol.0.user-enable-out net latch-ok-in => estop-latch.0.ok-in net latch0-out <= estop-latch.0.ok-out net latch0-out => estop-latch.1.ok-in net latch1-out <= estop-latch.1.ok-out net latch1-out => estop-latch.2.ok-in net latch2-out <= estop-latch.2.ok-out net latch2-out => estop-latch.3.ok-in #net latch3-out <= estop-latch.3.ok-out #net latch3-out => estop-latch.2.ok-in net latch-reset => estop-latch.0.reset net latch-reset => estop-latch.1.reset net latch-reset => estop-latch.2.reset net latch-reset => estop-latch.3.reset net latch-out iocontrol.0.emc-enable-in <= estop-latch.3.ok-out net estop-out estop-latch.3.fault-out # --- EXTERNAL ESTOP SWITCH - CONTROL BOX--- net external-estop <= hm2_7i76e.0.7i76.0.0.input-00 net external-estop => estop-latch.0.fault-in # --- EXTERNAL ESTOP SWITCH - CONSOLE --- net console-estop <= hm2_7i76e.0.7i76.0.0.input-31-not net console-estop => estop-latch.3.fault-in # --- PENDANT ESTOP SWITCH --- net pendant-estop <= hm2_7i76e.0.7i76.0.0.input-26-not net pendant-estop => estop-latch.1.fault-in # --- TORCH BREAKAWAY E-STOP --- net torch-breakaway <= hm2_7i76e.0.7i76.0.0.input-06 net torch-breakaway => estop-latch.2.fault-in # --- E-STOP STEPPER DRIVE DISABLE --- net estop-out hm2_7i76e.0.7i76.0.0.output-05 # --- E-STOP RED WARNING LIGHT --- net estop-out hm2_7i76e.0.7i76.0.0.output-00 net estop-out hm2_7i76e.0.7i76.0.0.output-10 # --- ESTOP CHAIN ENDS ---
24 Nov 2019 13:19 #151107
Here is a start. A bit of a work in progress really. You might need to implement shared home/limit switches or add a daughter baord if you want more inputs. BUt there is one left tfor your heating circuit
The following user(s) said Thank You: Muz94
24 Nov 2019 13:20 #151108
Ooops, ignore where it says Plasma. This is a reference pinout for a milling machine
- Muz94
24 Nov 2019 13:33 - 24 Nov 2019 13:39 #151109
by Muz94
I already have that implemented in my hal file, at the moment i have all the switches connected in series, and they work both as limit and home switches, using only 1 input.
However at the moment the heating is all managed by an arduino with a hand made "shield", it's connected to the pc throug serial (via usb) and it communicates with linucnc by a userspace hal component (a simple python script that manages the communication with the arduino and checks for alarms that should trigger the e-stop).
Even the e-stop latch works (i can trigger the e-stop if i call M104 and the thermistor is not connected or if i detect a temperature out of a "safe range"), but for now the e-stop just stops the program, if something really goes wrong i still can't cut the power.
Last edit: 24 Nov 2019 13:39 by Muz94.
- Thank you received: 7488
24 Nov 2019 13:44 #151111
Replied by tommylight on topic Control driver's power through linuxcnc
in that case all you need is to wire that e-stop signal to a physical pin on the parallel port, in hal.However at the moment the heating is all managed by an arduino with a hand made "shield", it's connected to the pc throug serial (via usb) and it communicates with linucnc by a userspace hal component (a simple python script that manages the communication with the arduino and checks for alarms that should trigger the e-stop).
25 Nov 2019 00:26 #151170
Well you can, you just use a mains power relay and control it exactly like I did here:
net estop-out hm2_7i76e.0.7i76.0.0.output-05Please Log in or Create an account to join the conversation.
