Ethercat Servo spindle orient example required
- snujcnc
- Thank you received: 4
01 Dec 2019 09:52 #151645
by snujcnc
Ethercat Servo spindle orient example required was created by snujcnc
Hi
I am working on ethercat servo which work well on axis
i can run ethercat servo spindle with s and m command ,
when i try to setup spindle orient function i fail every time
if anyone work on ethercat servo spindle with orient function working please share data .
i read many post about spindle orient but all are for different typpe for ready to use card for linuxcnc , i want setting for ethercat servo spindle
02 Dec 2019 14:49 #151753
Replied by andypugh on topic Ethercat Servo spindle orient example required
Does your spindle have orient built-in, or do you need to use a PID and velocity commands?
- snujcnc
05 Dec 2019 04:01 #152041
by snujcnc
Replied by snujcnc on topic Ethercat Servo spindle orient example required
I want to use PID and velocity command
(i also want to know about built in orient function in spindle drive)
05 Dec 2019 13:18 #152062
If you need to use PID to orient the spindle then I think that things look almost identical to any other spindle orient setup, except that the final output is a velocuty command on EtherCAT rather than a velocity command to a PWM generator.
The following user(s) said Thank You: snujcnc
- snujcnc
30 Dec 2019 04:20 #153540
by snujcnc
thank you
i tried to make orient working but i face issue with orient output ,
output is not working ok because wrong setting in pid
can you share any working orient setup so i can try to understand
07 Jan 2020 22:28 #154268
Can you post your HAL file?
- snujcnc
03 Mar 2020 03:18 #159061
by snujcnc
## scale
loadrt scale count=1
addf scale.0 servo-thread
setp scale.0.gain 0.0083
net spindle-speed-scale motion.spindle-speed-out => scale.0.in
net spindle-cmd-rpm <= scale.0.out
#net spindle-cmd-rpm => lcec.0.1.srv-vel-cmd
net spindle-on <= motion.spindle-on
### MUX2 ###
loadrt mux2 count=1
addf mux2.0 servo-thread
net orient-enable => mux2.0.sel
net orient-output => mux2.0.in1
net spindle-cmd-rpm => mux2.0.in0
net comand-to-drive mux2.0.out => lcec.0.1.srv-vel-cmd
loadrt invert count=1
addf invert.0 servo-thread
# motion interface
#spindle POSITION control
net spindle-encoder-raw-val conv-s32-float.0.in <= lcec.0.0.mop-spindle-encoder-raw-val
net spdl_encoder_pos motion.spindle-revs <= conv-s32-float.0.out
#spindle VELOCITY control
setp lcec.0.0.mop-encoder-scale 512
setp lcec.0.0.mop-spindle-ppr-val 20480
net speed-in lcec.0.0.mop-rps-raw-val => motion.spindle-speed-in
net spindle-index motion.spindle-index-enable <=> lcec.0.0.led-29-raw
net orient-enable => orient.enable
net orient-angle => orient.angle
net orient-mode => orient.mode
net orient-cmd-pid => orient.command
net spdl_encoder_pos => orient.position
net orient-enable <= motion.spindle-orient
net orient-angle <= motion.spindle-orient-angle
net orient-mode <= motion.spindle-orient-mode
#PID.0
setp pid.0.Pgain 1.0
setp pid.0.Igain 0.01
setp pid.0.Dgain 0.0
setp pid.0.FF0 0.0
setp pid.0.FF1 0.0
setp pid.0.FF2 0.0
#setp pid.0.bias
net spindle-cmd-rpm => pid.0.command ###
#pid.0.command-deriv
setp pid.0.deadband 0.1
net orient-enable => pid.0.enable ###
# pid.0.error
# pid.0.error-previous-target
net spdl_encoder_pos => pid.0.feedback
# pid.0.feedback-deriv
net spindle-index lcec.0.0.mop-spindle-index => pid.0.index-enable
# pid.0.maxcmdD 20.0
# pid.0.maxcmdDD
#setp pid.0.maxerror
#setp pid.0.maxerrorD
# pid.0.maxerrorI 20.0
net orient-output => pid.0.output
#setp pid.0.maxoutput 0.5
#net orient-output => invert.0.out
#net inv invert.0.in => pid.0.output
#pid.0.saturated
#pid.0.saturated-count
#pid.0.saturated-s
### MUX2 ###
loadrt mux2 count=1
# motion interface
#PID.0
setp pid.0.FF0 0.0
setp pid.0.FF1 0.0
setp pid.0.FF2 0.0
#setp pid.0.bias
# pid.0.error
# pid.0.maxcmdDD
#pid.0.saturated
#pid.0.saturated-s
05 Mar 2020 14:10 - 05 Mar 2020 14:11 #159256
Are you sure about this?
Is the raw-val a number scaled in counts? If it is then converting to a float won't give you spindle position.
motion.spindle-revs needs to increase by exactly 1.0 for each spindle rotation. You should be able to test this with halmeter.
net spdl_encoder_pos motion.spindle-revs <= conv-s32-float.0.outIs the raw-val a number scaled in counts? If it is then converting to a float won't give you spindle position.
Last edit: 05 Mar 2020 14:11 by andypugh.
- snujcnc
06 Mar 2020 14:05 - 06 Mar 2020 14:13 #159332
by snujcnc
i repaired my fault as you mentioned
thanks for help
now i can do orientation
thanks for help
Last edit: 06 Mar 2020 14:13 by snujcnc.
- snujcnc
07 Mar 2020 03:51 #159368
by snujcnc
One more question for orient holding
Torque after m19r0
1 which pid parameter responsible for increase holding torque after orient position arrive
(I use KEB vfd and want to add some torque ,I try to adjust p I d gain but no success)
Currently I set pid gain 500
And deadband 0.001
Maximum output 1000
All other parameter I set zero
Torque after m19r0
And deadband 0.001
Maximum output 1000
Time to create page: 0.143 seconds
