Low Speed for 3d Printing application
- Muz94
05 Dec 2019 14:22 #152097
by Muz94
The problem is that there are also moves withous extrusion, how can you deal with those? I fear it would take some additional effort
Replied by Muz94 on topic Low Speed for 3d Printing application
One way to avoid the entire TP issue is to use velocity based extrusion.
For optimal operation, this probably requires delaying the motion in hal
before its feed to the joints so the extruder response over time can be
modelled and compensated
I believe that Machine kit has implemented a delay component that could
be used for delaying motion. If simple lookahead is not good enough, a
FIR filter could be used to process the velocity signal. All of this is pretty
slow so a servo thread loop time resolution should be fine.
How would this work? Do you need to make changes in the gcode to have velocity data or it can be done with the information already present in a normal slicer gcode?
Do you have any advice on where to start?
In the very simplest case you would take motion.current-vel, scale it and feed it to the extruder stepgen velocity
Next would be to delay all motion joints with a delay component and feed the non-delayed velocity to the stepgen
Fancier would be to feed the non-delayed velocity to a filter that compensates for the time domain response
of the extruder
- Muz94
05 Dec 2019 14:24 #152098
by Muz94
What is this?Hopefully in the pipeline.
“The good news is, I have a branch that supersedes it, and does a slightly more complex blend (using two tangential arcs), and can also blend in ABC as well.”
05 Dec 2019 14:39 #152102
Potentially good news from an email.
Replied by andypugh on topic Low Speed for 3d Printing application
What is this?
05 Dec 2019 14:42 #152105
hackaday.com/2014/05/10/blobless-printin...-velocity-extrusion/
- Muz94
05 Dec 2019 14:46 #152106
by Muz94
:0 is there a way to access that branch?
What is this?
- Muz94
05 Dec 2019 14:47 #152107
by Muz94
I was reading exactly that (and this, where there is a detailed explaination basdebruijn.com/2014/09/velocity-extruding-revisited/)
Very cool and interesting, but also a very hard work to replicate, i will have to find a different solution if possible.
06 Dec 2019 03:34 #152135
The basic idea is much simpler than it sounds from that write-up.
Though I don't think it is trivial to work-in filament retraction.
- Muz94
06 Dec 2019 06:36 #152151
by Muz94
Yes, it's absolutely feasible, but I just don't have the time for a project like that. Tonight I'll try to turn my config. Into a simulator and swap U and Z axis.
Do you think there might be a way to delay the u axis without driving it in velocity mode?
- Thank you received: 5336
06 Dec 2019 08:45 - 06 Dec 2019 08:46 #152158
I would think that this could be handled with acceleration factored in
(perhaps with some accel/deccel assymetry)
Replied by PCW on topic Low Speed for 3d Printing application
Last edit: 06 Dec 2019 08:46 by PCW.
- Muz94
06 Dec 2019 12:23 #152167
by Muz94
The author of this config. confirmed that this solved his issues, so i have a question: would it be hard to change the setup in the TP so that the blending happens between XYU instead of XYZ? This would be much more elegant than working with a machine with swapped axes. Is it just a matter of changing a few lines of code and recompiling or what?
While looking around for an idea i came across to this configuration :
github.com/dabit20/rpi_cnc
and guess what? he runs the machine with swapped A - Z axes.
I'll try to ask him if he did that to fix this exact problem
Time to create page: 1.436 seconds
