- Thank you received: 4153
rodw wrote: Thats the thing, you cannot simply extract the real time requirement from Linuxcnc. That is at its core. It can't be extracted!
The Mesa FGPA cards generate the step pulses but it is Linuxcnc which tells them what frequency to run at. Soit is clear you still don't understand the environment with linuxcnc.
You really need to stop this nonsense and research the Linuxcnc architecture. If you did that, you might actually begin to understand the amazing benefits real time bring to linuxcnc..
