I could use some help with the error report below. It appears to to complain that the file already exists? The system is a paraport using stepconfig in linux min 19.3 using the precompiled RTAI files from Andy.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-4.14.132-rtai-amd64/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/mill/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/mill/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z A
KINEMATICS=trivkins coordinates=XYZA
Starting LinuxCNC...
Realtime system did not load
Debug file information:
insmod: ERROR: could not insert module /usr/realtime-4.14.132-rtai-amd64/modules/rtai_hal.ko: File exists
2279
Stopping realtime threads
Unloading hal components
rmmod: ERROR: Module hal_lib is not currently loaded
rmmod: ERROR: Module rtapi is not currently loaded
rmmod: ERROR: Module rtai_math is not currently loaded
rmmod: ERROR: Module rtai_sched is in use
rmmod: ERROR: Module rtai_hal is in use by: rtai_sched
Kernel message information:
dmesg: read kernel buffer failed: Operation not permitted
dmesg requires root privilege on this system
Description: Linux Mint 19.3 Tricia
Use a terminal to issue the command: sudo dmesg
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri Dec 27 03:05:58 EST 2019
UTC Date: Fri Dec 27 08:05:58 UTC 2019
this program: /usr/bin/linuxcnc_info
uptime: 03:05:58 up 1 min, 1 user, load average: 1.46, 0.59, 0.22
lsb_release -sa: LinuxMint Linux Mint 19.3 Tricia 19.3 tricia
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/mill/linuxcnc/configs/my-mill
USER: mill
LOGNAME: mill
HOME: /home/mill
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1680x1050 pixels (444x277 millimeters)
PATH: /usr/bin:/home/mill/linuxcnc/configs/my-mill/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: mill-DIY
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Mon Jul 8 23:47:38 BST 2019
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.14.132-rtai-amd64 root=UUID=1bb2ab4d-56cb-4325-b04d-37b4eaa83c40 ro quiet splash vt.handoff=1
model name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cores: 4
cpu MHz: 1966.165
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0
python: Python 2.7.17
git: git version 2.17.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-4.14.132-rtai-amd64/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii linuxcnc 1:2.8.0~pre1.4891.gadf1eff73 amd64 motion controller for CNC machines and robots
ii linuxcnc-dev 1:2.8.0~pre1.4891.gadf1eff73 amd64 PC based motion controller for real-time Linux
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.4891.gadf1eff73 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
un linuxcnc-uspace <none> <none> (no description available)
un linuxcnc-uspace-dev <none> <none> (no description available)
