- LinuxCNC
- General LinuxCNC Questions
- Realtime system did not load. insmod: ERROR: could not insert module /usr/realti
- MDM3D
27 Dec 2019 08:16 #153256
by MDM3D
Realtime system did not load. insmod: ERROR: could not insert module /usr/realti was created by MDM3D
I could use some help with the error report below. It appears to to complain that the file already exists? The system is a paraport using stepconfig in linux min 19.3 using the precompiled RTAI files from Andy.
Thanks in Advance!
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-4.14.132-rtai-amd64/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/mill/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/mill/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z A
KINEMATICS=trivkins coordinates=XYZA
Starting LinuxCNC...
Debug file information:
insmod: ERROR: could not insert module /usr/realtime-4.14.132-rtai-amd64/modules/rtai_hal.ko: File exists
2279
Stopping realtime threads
Unloading hal components
rmmod: ERROR: Module hal_lib is not currently loaded
rmmod: ERROR: Module rtapi is not currently loaded
rmmod: ERROR: Module rtai_math is not currently loaded
rmmod: ERROR: Module rtai_sched is in use
rmmod: ERROR: Module rtai_hal is in use by: rtai_sched
Kernel message information:
dmesg: read kernel buffer failed: Operation not permitted
dmesg requires root privilege on this system
Description: Linux Mint 19.3 Tricia
Use a terminal to issue the command: sudo dmesg
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri Dec 27 03:05:58 EST 2019
UTC Date: Fri Dec 27 08:05:58 UTC 2019
this program: /usr/bin/linuxcnc_info
uptime: 03:05:58 up 1 min, 1 user, load average: 1.46, 0.59, 0.22
lsb_release -sa: LinuxMint Linux Mint 19.3 Tricia 19.3 tricia
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/mill/linuxcnc/configs/my-mill
USER: mill
LOGNAME: mill
HOME: /home/mill
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1680x1050 pixels (444x277 millimeters)
PATH: /usr/bin:/home/mill/linuxcnc/configs/my-mill/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: mill-DIY
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Mon Jul 8 23:47:38 BST 2019
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.14.132-rtai-amd64 root=UUID=1bb2ab4d-56cb-4325-b04d-37b4eaa83c40 ro quiet splash vt.handoff=1
model name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cores: 4
cpu MHz: 1966.165
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0
python: Python 2.7.17
git: git version 2.17.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-4.14.132-rtai-amd64/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii linuxcnc 1:2.8.0~pre1.4891.gadf1eff73 amd64 motion controller for CNC machines and robots
ii linuxcnc-dev 1:2.8.0~pre1.4891.gadf1eff73 amd64 PC based motion controller for real-time Linux
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.4891.gadf1eff73 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
un linuxcnc-uspace <none> <none> (no description available)
un linuxcnc-uspace-dev <none> <none> (no description available)Thanks in Advance!
- Thank you received: 5321
27 Dec 2019 18:45 #153300
Replied by PCW on topic Realtime system did not load. insmod: ERROR: could not insert module /usr/realti
Errors like the above usually result from launching LinuxCNC when LinuxCNC or another LinuxCNC real time utility is running
This also often happens when a LinuxCNC launch fails but does not successfully clean up after itself
You might try
halrun -U
which is supposed to unload the real time modules, but often times, a reboot is required
You might try
halrun -U
- MDM3D
27 Dec 2019 18:54 - 27 Dec 2019 19:04 #153301
by MDM3D
Replied by MDM3D on topic Realtime system did not load. insmod: ERROR: could not insert module /usr/realti
PCW thank you for the quick reply, Unfortunately this problem exists through a reboot and a shutdown, latency test also fails to load and will not run. It also fails to provide an error message. Do you have any other places I could look? When I run your command I get
Also this is a new install as I am upgrading from mint 18.3 with 2.7.8.
mill@mill-DIY:~$ halrun -U
rmmod: ERROR: Module rtai_hal is in use by: rtai_schedAlso this is a new install as I am upgrading from mint 18.3 with 2.7.8.
Last edit: 27 Dec 2019 19:04 by MDM3D.
27 Dec 2019 19:09 #153302
Did you reboot and try LinuxCNC first?
If the latency-test failed, its likely LinuxCNC will fail due to lack of cleanup
as indicated here:
as indicated here:
- MDM3D
27 Dec 2019 19:22 #153303
by MDM3D
Yes first thing I did after reboot was run launch mill. I got the 2.8.0 -Pre1 splash screen and then it went away but AXIS did not show up.
I waited ~5 mins then ran launch Mill again. I got an error message saying linuxcnc is running would you like to restart it. I pressed yes and got the error report above again.
27 Dec 2019 19:31 #153305
I guess what I am trying to say is the real problem is masked by re-launching LinuxCNC after it (or latency-test) fails
The most valuable diagnostic information would be in the error report
after the first launch of LinuxCNC after a reboot, if you launch
LinuxCNC again, this information is lost
- MDM3D
27 Dec 2019 21:45 #153318
by MDM3D
The only file that is in tmp and not blank is linuxcnc.print.RvJvGU it is attached below.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
Machine configuration directory is '/home/mill/linuxcnc/configs/Mill'
Machine configuration file is 'Mill.ini'
INIFILE=/home/mill/linuxcnc/configs/Mill/Mill.ini
VERSION=1.1
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z A
Loading Real Time OS, RTAPI, and HAL_LIB modulesPlease Log in or Create an account to join the conversation.
27 Dec 2019 21:48 #153319
what does dmesg show?
- MDM3D
28 Dec 2019 04:17 #153355
by MDM3D
Please see below.
mill@mill-DIY:~$ sudo dmesg
[sudo] password for mill:
[ 0.000000] Linux version 4.14.132-rtai-amd64 (root@rm-one) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Mon Jul 8 23:47:38 BST 2019
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.14.132-rtai-amd64 root=UUID=1bb2ab4d-56cb-4325-b04d-37b4eaa83c40 ro quiet splash vt.handoff=1
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ebff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bfdffbff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bfdffc00-0x00000000bfe53bff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bfe53c00-0x00000000bfe55bff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bfe55c00-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001b7ffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 780 /03NVJ6, BIOS A15 08/06/2013
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x1b8000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0BFF00000 mask FFFF00000 uncachable
[ 0.000000] 1 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: last_pfn = 0xbfdff max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fe710-0x000fe71f]
[ 0.000000] Base memory trampoline at [ffff888000098000] 98000 size 24576
[ 0.000000] BRK [0x01e34000, 0x01e34fff] PGTABLE
[ 0.000000] BRK [0x01e35000, 0x01e35fff] PGTABLE
[ 0.000000] BRK [0x01e36000, 0x01e36fff] PGTABLE
[ 0.000000] BRK [0x01e37000, 0x01e37fff] PGTABLE
[ 0.000000] BRK [0x01e38000, 0x01e38fff] PGTABLE
[ 0.000000] BRK [0x01e39000, 0x01e39fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x32529000-0x3528bfff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FEC00 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000000FC7F2 000074 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 0x00000000000FC922 0000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20170728/tbfadt-603)
[ 0.000000] ACPI: DSDT 0x00000000FFEA3664 005035 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 0x00000000BFDFFC00 000040
[ 0.000000] ACPI: SSDT 0x00000000FFEA87BA 0000AC (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 0x00000000000FCA16 000092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 0x00000000000FCAA8 000028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 0x00000000000FCAD0 000096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 0x00000000000FCB66 00003C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 0x00000000000FCBA2 000038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 0x00000000000FCDFE 000032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DMAR 0x00000000000FCE30 0000D8 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 0x00000000000FCBDA 000176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001b7ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000bfdfefff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001b7ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000001b7ffffff]
[ 0.000000] On node 0 totalpages: 1539484
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 12216 pages used for memmap
[ 0.000000] DMA32 zone: 781823 pages, LIFO batch:31
[ 0.000000] Normal zone: 11776 pages used for memmap
[ 0.000000] Normal zone: 753664 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] e820: [mem 0xc0000000-0xf7ffffff] available for PCI devices
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:16 nr_cpumask_bits:16 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] percpu: Embedded 60 pages/cpu s205464 r8192 d32104 u524288
[ 0.000000] pcpu-alloc: s205464 r8192 d32104 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1515407
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14.132-rtai-amd64 root=UUID=1bb2ab4d-56cb-4325-b04d-37b4eaa83c40 ro quiet splash vt.handoff=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 5921252K/6157936K available (8200K kernel code, 366K rwdata, 1628K rodata, 944K init, 872K bss, 236684K reserved, 0K cma-reserved)
[ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x4c/0x100 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[ 0.000000] RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 4352, nr_irqs: 456, preallocated irqs: 16
[ 0.000000] Interrupt pipeline (release #5)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.004000] tsc: Detected 2393.826 MHz processor
[ 0.004000] Calibrating delay loop (skipped), value calculated using timer frequency.. 4787.65 BogoMIPS (lpj=9575304)
[ 0.004000] pid_max: default: 32768 minimum: 301
[ 0.004000] ACPI: Core revision 20170728
[ 0.091359] ACPI BIOS Warning (bug): Incorrect checksum in table [TCPA] - 0x00, should be 0x7F (20170728/tbprint-211)
[ 0.168041] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.168156] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.168228] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.168460] mce: CPU supports 6 MCE banks
[ 0.168466] CPU0: Thermal monitoring enabled (TM1)
[ 0.168469] process: using mwait in idle threads
[ 0.168474] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.168475] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.168478] Spectre V2 : Spectre mitigation: kernel not compiled with retpoline; no mitigation available!
[ 0.168479] Speculative Store Bypass: Vulnerable
[ 0.168487] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.168552] Freeing SMP alternatives memory: 20K
[ 0.169019] smpboot: Max logical packages: 2
[ 0.169393] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.212000] smpboot: CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (family: 0x6, model: 0xf, stepping: 0xb)
[ 0.224011] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.224022] core: PEBS disabled due to CPU errata
[ 0.224025] ... version: 2
[ 0.224027] ... bit width: 40
[ 0.224028] ... generic registers: 2
[ 0.224030] ... value mask: 000000ffffffffff
[ 0.224032] ... max period: 000000007fffffff
[ 0.224033] ... fixed-purpose events: 3
[ 0.224035] ... event mask: 0000000700000003
[ 0.232005] Hierarchical SRCU implementation.
[ 0.256004] smp: Bringing up secondary CPUs ...
[ 0.288014] x86: Booting SMP configuration:
[ 0.288016] .... node #0, CPUs: #1 #2 #3
[ 0.359482] smp: Brought up 1 node, 4 CPUs
[ 0.359482] smpboot: Total of 4 processors activated (19150.60 BogoMIPS)
[ 0.360290] devtmpfs: initialized
[ 0.360290] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.360290] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.360290] pinctrl core: initialized pinctrl subsystem
[ 0.360290] NET: Registered protocol family 16
[ 0.360415] Simple Boot Flag at 0x7a set to 0x1
[ 0.360423] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.360424] ACPI: bus type PCI registered
[ 0.360479] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.360482] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.360490] PCI: Using configuration type 1 for base access
[ 0.364542] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.364542] ACPI: Added _OSI(Module Device)
[ 0.364542] ACPI: Added _OSI(Processor Device)
[ 0.364542] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.364542] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.403524] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.442669] ACPI: Interpreter enabled
[ 0.442675] ACPI: (supports S0 S5)
[ 0.442677] ACPI: Using IOAPIC for interrupt routing
[ 0.442792] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.443015] ACPI: Enabled 14 GPEs in block 00 to 3F
[ 0.668764] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.668769] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig Segments MSI]
[ 0.668773] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.668777] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.677197] PCI host bridge to bus 0000:00
[ 0.677200] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.677202] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.677204] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.677206] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff window]
[ 0.677207] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.677209] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfec00000 window]
[ 0.677211] pci_bus 0000:00: root bus resource [mem 0xbff00000-0xf7ffffff window]
[ 0.677213] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff window]
[ 0.677214] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff window]
[ 0.677216] pci_bus 0000:00: root bus resource [mem 0xff970000-0xff9707ff window]
[ 0.677218] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff window]
[ 0.677219] pci_bus 0000:00: root bus resource [mem 0xfeda6000-0xfeda6fff window]
[ 0.677221] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff window]
[ 0.677223] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.677232] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.677591] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.677630] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.677966] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.677993] pci 0000:00:03.0: reg 0x10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.678074] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.678405] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.678429] pci 0000:00:03.2: reg 0x10: [io 0xfe80-0xfe87]
[ 0.678440] pci 0000:00:03.2: reg 0x14: [io 0xfe90-0xfe93]
[ 0.678450] pci 0000:00:03.2: reg 0x18: [io 0xfea0-0xfea7]
[ 0.678460] pci 0000:00:03.2: reg 0x1c: [io 0xfeb0-0xfeb3]
[ 0.678470] pci 0000:00:03.2: reg 0x20: [io 0xfef0-0xfeff]
[ 0.678861] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.678885] pci 0000:00:03.3: reg 0x10: [io 0xecb8-0xecbf]
[ 0.678895] pci 0000:00:03.3: reg 0x14: [mem 0xf7fd8000-0xf7fd8fff]
[ 0.679324] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.679341] pci 0000:00:19.0: reg 0x10: [mem 0xf7fe0000-0xf7ffffff]
[ 0.679349] pci 0000:00:19.0: reg 0x14: [mem 0xf7fd9000-0xf7fd9fff]
[ 0.679357] pci 0000:00:19.0: reg 0x18: [io 0xece0-0xecff]
[ 0.679412] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.679737] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.679779] pci 0000:00:1a.0: reg 0x20: [io 0xff20-0xff3f]
[ 0.680160] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.680201] pci 0000:00:1a.1: reg 0x20: [io 0xff00-0xff1f]
[ 0.680561] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.680602] pci 0000:00:1a.2: reg 0x20: [io 0xfc00-0xfc1f]
[ 0.680967] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.680988] pci 0000:00:1a.7: reg 0x10: [mem 0xf7fda000-0xf7fda3ff]
[ 0.681066] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.681396] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.681416] pci 0000:00:1b.0: reg 0x10: [mem 0xf7fdc000-0xf7fdffff 64bit]
[ 0.681482] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.681810] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.681879] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.682213] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.682281] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.682619] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.682661] pci 0000:00:1d.0: reg 0x20: [io 0xff80-0xff9f]
[ 0.683020] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.683062] pci 0000:00:1d.1: reg 0x20: [io 0xff60-0xff7f]
[ 0.683421] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.683463] pci 0000:00:1d.2: reg 0x20: [io 0xff40-0xff5f]
[ 0.683833] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.683864] pci 0000:00:1d.7: reg 0x10: [mem 0xff980000-0xff9803ff]
[ 0.683944] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.684279] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.684651] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100
[ 0.685075] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.685092] pci 0000:00:1f.2: reg 0x10: [io 0xfe00-0xfe07]
[ 0.685099] pci 0000:00:1f.2: reg 0x14: [io 0xfe10-0xfe13]
[ 0.685106] pci 0000:00:1f.2: reg 0x18: [io 0xfe20-0xfe27]
[ 0.685113] pci 0000:00:1f.2: reg 0x1c: [io 0xfe30-0xfe33]
[ 0.685121] pci 0000:00:1f.2: reg 0x20: [io 0xfec0-0xfedf]
[ 0.685128] pci 0000:00:1f.2: reg 0x24: [mem 0xff970000-0xff9707ff]
[ 0.685166] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.685490] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.685508] pci 0000:00:1f.3: reg 0x10: [mem 0xf7fdb000-0xf7fdb0ff 64bit]
[ 0.685527] pci 0000:00:1f.3: reg 0x20: [io 0x0980-0x099f]
[ 0.685895] pci 0000:01:00.0: [1002:9498] type 00 class 0x030000
[ 0.685913] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.685923] pci 0000:01:00.0: reg 0x18: [mem 0xf7df0000-0xf7dfffff 64bit]
[ 0.685930] pci 0000:01:00.0: reg 0x20: [io 0xdc00-0xdcff]
[ 0.685942] pci 0000:01:00.0: reg 0x30: [mem 0xf7e00000-0xf7e1ffff pref]
[ 0.685977] pci 0000:01:00.0: supports D1 D2
[ 0.686012] pci 0000:01:00.1: [1002:aa38] type 00 class 0x040300
[ 0.686030] pci 0000:01:00.1: reg 0x10: [mem 0xf7dec000-0xf7deffff 64bit]
[ 0.686089] pci 0000:01:00.1: supports D1 D2
[ 0.686119] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.686122] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.686125] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 0.686128] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.686160] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.686165] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.686201] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.686206] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.686266] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.686275] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.686277] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.686279] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.686281] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff window] (subtractive decode)
[ 0.686282] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff window] (subtractive decode)
[ 0.686284] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfec00000 window] (subtractive decode)
[ 0.686286] pci 0000:00:1e.0: bridge window [mem 0xbff00000-0xf7ffffff window] (subtractive decode)
[ 0.686288] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff window] (subtractive decode)
[ 0.686290] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff window] (subtractive decode)
[ 0.686292] pci 0000:00:1e.0: bridge window [mem 0xff970000-0xff9707ff window] (subtractive decode)
[ 0.686294] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff window] (subtractive decode)
[ 0.686296] pci 0000:00:1e.0: bridge window [mem 0xfeda6000-0xfeda6fff window] (subtractive decode)
[ 0.686298] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff window] (subtractive decode)
[ 0.686314] pci_bus 0000:00: on NUMA node 0
[ 0.712974] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.713869] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.714765] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.715653] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.716675] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.717564] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.718456] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.719356] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.719832] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.719832] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.719832] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.719832] vgaarb: loaded
[ 0.719832] EDAC MC: Ver: 3.0.0
[ 0.720040] PCI: Using ACPI for IRQ routing
[ 0.721455] PCI: pci_cache_line_size set to 64 bytes
[ 0.721501] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.721503] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.721505] e820: reserve RAM buffer [mem 0x0009ec00-0x0009ffff]
[ 0.721506] e820: reserve RAM buffer [mem 0xbfdffc00-0xbfffffff]
[ 0.722589] HPET: 8 timers in total, 4 timers will be used for per-cpu timer
[ 0.722596] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 24, 25, 26, 27, 0, 0
[ 0.722605] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.724030] hpet: hpet2 irq 24 for MSI
[ 0.724051] hpet: hpet3 irq 25 for MSI
[ 0.724051] hpet: hpet4 irq 26 for MSI
[ 0.728022] hpet: hpet5 irq 27 for MSI
[ 0.728038] clocksource: Switched to clocksource hpet
[ 0.728111] VFS: Disk quotas dquot_6.6.0
[ 0.728149] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.728204] pnp: PnP ACPI init
[ 0.731704] system 00:00: [io 0x0800-0x085f] has been reserved
[ 0.731707] system 00:00: [io 0x0c00-0x0c7f] has been reserved
[ 0.731709] system 00:00: [io 0x0860-0x08ff] has been reserved
[ 0.731714] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.731936] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.746281] pnp 00:02: [dma 0 disabled]
[ 0.747463] pnp 00:02: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.752830] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.768223] pnp: PnP ACPI: found 4 devices
[ 0.774332] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.774348] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.774351] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.774358] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.774360] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.774379] pci 0000:00:1c.0: BAR 9: assigned [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.774386] pci 0000:00:1c.1: BAR 9: assigned [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.774389] pci 0000:00:1c.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.774391] pci 0000:00:1c.1: BAR 7: assigned [io 0x2000-0x2fff]
[ 0.774394] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.774397] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.774400] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 0.774403] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.774407] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.774410] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.774414] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.774417] pci 0000:00:1c.0: bridge window [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.774422] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.774425] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.774429] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.774432] pci 0000:00:1c.1: bridge window [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.774438] pci 0000:00:1e.0: PCI bridge to [bus 04]
[ 0.774448] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.774450] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.774451] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.774453] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.774455] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.774457] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfec00000 window]
[ 0.774459] pci_bus 0000:00: resource 10 [mem 0xbff00000-0xf7ffffff window]
[ 0.774461] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff window]
[ 0.774463] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.774464] pci_bus 0000:00: resource 13 [mem 0xff970000-0xff9707ff window]
[ 0.774466] pci_bus 0000:00: resource 14 [mem 0xfed20000-0xfed9ffff window]
[ 0.774468] pci_bus 0000:00: resource 15 [mem 0xfeda6000-0xfeda6fff window]
[ 0.774470] pci_bus 0000:00: resource 16 [mem 0xfeda7000-0xfeda7fff window]
[ 0.774471] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.774473] pci_bus 0000:01: resource 1 [mem 0xf7d00000-0xf7efffff]
[ 0.774475] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.774477] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.774479] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.774480] pci_bus 0000:02: resource 2 [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.774482] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.774484] pci_bus 0000:03: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.774485] pci_bus 0000:03: resource 2 [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.774487] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.774489] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.774491] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.774493] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.774494] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.774496] pci_bus 0000:04: resource 9 [mem 0xfc000000-0xfec00000 window]
[ 0.774498] pci_bus 0000:04: resource 10 [mem 0xbff00000-0xf7ffffff window]
[ 0.774500] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff window]
[ 0.774502] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.774503] pci_bus 0000:04: resource 13 [mem 0xff970000-0xff9707ff window]
[ 0.774505] pci_bus 0000:04: resource 14 [mem 0xfed20000-0xfed9ffff window]
[ 0.774507] pci_bus 0000:04: resource 15 [mem 0xfeda6000-0xfeda6fff window]
[ 0.774509] pci_bus 0000:04: resource 16 [mem 0xfeda7000-0xfeda7fff window]
[ 0.774569] NET: Registered protocol family 2
[ 0.774708] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.774838] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.775092] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.775133] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.775169] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.775250] NET: Registered protocol family 1
[ 0.782368] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.782373] PCI: CLS 64 bytes, default 64
[ 0.782412] Unpacking initramfs...
[ 1.428012] random: fast init done
[ 1.529857] Freeing initrd memory: 46476K
[ 1.529863] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.529865] software IO TLB: mapped [mem 0xbbdff000-0xbfdff000] (64MB)
[ 1.530465] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.531450] zbud: loaded
[ 1.532571] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.532647] io scheduler noop registered
[ 1.532649] io scheduler deadline registered
[ 1.532689] io scheduler cfq registered (default)
[ 1.532690] io scheduler mq-deadline registered
[ 1.532692] io scheduler kyber registered
[ 1.532794] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 1.532795] vesafb: scrolling: redraw
[ 1.532797] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.532810] vesafb: framebuffer at 0xe0000000, mapped to 0xffffc90000400000, using 1216k, total 1216k
[ 1.542294] Console: switching to colour frame buffer device 80x30
[ 1.551662] fb0: VESA VGA frame buffer device
[ 1.551713] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.572154] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.592993] 0000:00:03.3: ttyS1 at I/O 0xecb8 (irq = 17, base_baud = 115200) is a 16550A
[ 1.593348] Linux agpgart interface v0.103
[ 1.593815] i8042: PNP: No PS/2 controller found.
[ 1.593816] i8042: Probing ports directly.
[ 1.596728] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.596749] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.596816] mousedev: PS/2 mouse device common for all mice
[ 1.596856] rtc_cmos 00:01: RTC can wake from S4
[ 1.596941] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.596961] rtc_cmos 00:01: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.597479] NET: Registered protocol family 10
[ 1.597748] Segment Routing with IPv6
[ 1.597764] mip6: Mobile IPv6
[ 1.597767] NET: Registered protocol family 17
[ 1.597769] mpls_gso: MPLS GSO support
[ 1.597986] microcode: sig=0x6fb, pf=0x10, revision=0xba
[ 1.598060] microcode: Microcode Update Driver: v2.2.
[ 1.598073] sched_clock: Marking stable (1598052888, 0)->(1706645061, -108592173)
[ 1.598175] registered taskstats version 1
[ 1.598203] zswap: loaded using pool lzo/zbud
[ 1.598490] rtc_cmos 00:01: setting system clock to 2019-12-27 21:36:10 UTC (1577482570)
[ 1.599406] Freeing unused kernel memory: 944K
[ 1.599409] Write protecting the kernel read-only data: 12288k
[ 1.600348] Freeing unused kernel memory: 2020K
[ 1.601515] Freeing unused kernel memory: 420K
[ 1.601614] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.651773] ACPI: bus type USB registered
[ 1.651809] usbcore: registered new interface driver usbfs
[ 1.651825] usbcore: registered new interface driver hub
[ 1.651855] usbcore: registered new device driver usb
[ 1.654407] pps_core: LinuxPPS API ver. 1 registered
[ 1.654409] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.654794] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.655044] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.655599] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.655607] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.655639] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 1.655954] PTP clock support registered
[ 1.656176] ehci-pci: EHCI PCI platform driver
[ 1.656213] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.656215] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.656217] usb usb1: Product: UHCI Host Controller
[ 1.656219] usb usb1: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.656221] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.656349] hub 1-0:1.0: USB hub found
[ 1.656357] hub 1-0:1.0: 2 ports detected
[ 1.656991] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.657003] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 1.657040] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 1.657090] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.657093] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.657095] usb usb2: Product: UHCI Host Controller
[ 1.657096] usb usb2: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.657098] usb usb2: SerialNumber: 0000:00:1a.1
[ 1.657224] hub 2-0:1.0: USB hub found
[ 1.657231] hub 2-0:1.0: 2 ports detected
[ 1.657921] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.657926] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 3
[ 1.657938] ehci-pci 0000:00:1a.7: debug port 1
[ 1.658941] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.658942] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.661853] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 1.661865] ehci-pci 0000:00:1a.7: irq 22, io mem 0xf7fda000
[ 1.664382] SCSI subsystem initialized
[ 1.666148] libata version 3.00 loaded.
[ 1.667515] [drm] radeon kernel modesetting enabled.
[ 1.667745] checking generic (e0000000 130000) vs hw (e0000000 10000000)
[ 1.667747] fb: switching to radeondrmfb from VESA VGA
[ 1.667775] Console: switching to colour dummy device 80x25
[ 1.670124] [drm] initializing kernel modesetting (RV730 0x1002:0x9498 0x174B:0xE109 0x00).
[ 1.670303] ATOM BIOS:
[ 1.670421] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 1.670423] radeon 0000:01:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[ 1.670528] [drm] Detected VRAM RAM=512M, BAR=256M
[ 1.670529] [drm] RAM width 128bits DDR
[ 1.672109] [TTM] Zone kernel: Available graphics memory: 2985566 kiB
[ 1.672111] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 1.672112] [TTM] Initializing pool allocator
[ 1.672119] [TTM] Initializing DMA pool allocator
[ 1.672147] [drm] radeon: 512M of VRAM memory ready
[ 1.672148] [drm] radeon: 1024M of GTT memory ready.
[ 1.672155] [drm] Loading RV730 Microcode
[ 1.672223] [drm] Internal thermal controller with fan control
[ 1.673437] [drm] radeon: dpm initialized
[ 1.673521] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 1.674816] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 1.679254] [drm] PCIE GART of 1024M enabled (table at 0x000000000014C000).
[ 1.679293] radeon 0000:01:00.0: WB enabled
[ 1.679296] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff8881a83b3c00
[ 1.679298] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff8881a83b3c0c
[ 1.679554] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x000000000005c598 and cpu addr 0xffffc9000081c598
[ 1.679557] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.679558] [drm] Driver supports precise vblank timestamp query.
[ 1.679559] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 1.679603] radeon 0000:01:00.0: radeon: using MSI.
[ 1.679627] [drm] radeon: irq initialized.
[ 1.680041] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.680093] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.680096] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.680098] usb usb3: Product: EHCI Host Controller
[ 1.680099] usb usb3: Manufacturer: Linux 4.14.132-rtai-amd64 ehci_hcd
[ 1.680101] usb usb3: SerialNumber: 0000:00:1a.7
[ 1.680235] hub 3-0:1.0: USB hub found
[ 1.680244] hub 3-0:1.0: 6 ports detected
[ 1.680373] hub 1-0:1.0: USB hub found
[ 1.680381] hub 1-0:1.0: 2 ports detected
[ 1.680453] hub 2-0:1.0: USB hub found
[ 1.680461] hub 2-0:1.0: 2 ports detected
[ 1.681039] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.681044] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 4
[ 1.681055] ehci-pci 0000:00:1d.7: debug port 1
[ 1.684956] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.684969] ehci-pci 0000:00:1d.7: irq 23, io mem 0xff980000
[ 1.700035] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.700066] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.700068] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.700070] usb usb4: Product: EHCI Host Controller
[ 1.700072] usb usb4: Manufacturer: Linux 4.14.132-rtai-amd64 ehci_hcd
[ 1.700074] usb usb4: SerialNumber: 0000:00:1d.7
[ 1.700182] hub 4-0:1.0: USB hub found
[ 1.700188] hub 4-0:1.0: 6 ports detected
[ 1.700796] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.700802] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 1.700825] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 1.700881] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.700883] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.700885] usb usb5: Product: UHCI Host Controller
[ 1.700887] usb usb5: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.700889] usb usb5: SerialNumber: 0000:00:1a.2
[ 1.701000] hub 5-0:1.0: USB hub found
[ 1.701007] hub 5-0:1.0: 2 ports detected
[ 1.701560] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.701566] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.701588] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 1.701635] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.701637] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.701639] usb usb6: Product: UHCI Host Controller
[ 1.701641] usb usb6: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.701643] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.701738] hub 6-0:1.0: USB hub found
[ 1.701745] hub 6-0:1.0: 2 ports detected
[ 1.702333] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.725962] [drm] ring test on 0 succeeded in 1 usecs
[ 1.725968] [drm] ring test on 3 succeeded in 2 usecs
[ 1.894208] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) a4:ba:db:ea:95:9d
[ 1.894213] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 1.894259] e1000e 0000:00:19.0 eth0: MAC: 8, PHY: 8, PBA No: 2011FF-0FF
[ 1.895098] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[ 1.899037] scsi host0: ata_generic
[ 1.899123] scsi host1: ata_generic
[ 1.899156] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 1.899158] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 1.899184] ahci 0000:00:1f.2: version 3.0
[ 1.899722] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x27 impl SATA mode
[ 1.899725] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 1.910544] [drm] ring test on 5 succeeded in 1 usecs
[ 1.910548] [drm] UVD initialized successfully.
[ 1.910986] [drm] ib test on ring 0 succeeded in 0 usecs
[ 1.911002] [drm] ib test on ring 3 succeeded in 0 usecs
[ 1.936441] scsi host2: ahci
[ 1.940552] scsi host3: ahci
[ 1.944659] scsi host4: ahci
[ 1.948770] scsi host5: ahci
[ 1.952876] scsi host6: ahci
[ 1.956980] scsi host7: ahci
[ 1.957018] ata3: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970100 irq 30
[ 1.957020] ata4: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970180 irq 30
[ 1.957022] ata5: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970200 irq 30
[ 1.957023] ata6: DUMMY
[ 1.957024] ata7: DUMMY
[ 1.957026] ata8: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970380 irq 30
[ 1.957539] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.957547] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.957569] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 1.957626] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.957628] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.957630] usb usb7: Product: UHCI Host Controller
[ 1.957631] usb usb7: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.957633] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.957727] hub 7-0:1.0: USB hub found
[ 1.957734] hub 7-0:1.0: 2 ports detected
[ 1.958260] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.958266] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.958287] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.958338] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.958340] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.958342] usb usb8: Product: UHCI Host Controller
[ 1.958344] usb usb8: Manufacturer: Linux 4.14.132-rtai-amd64 uhci_hcd
[ 1.958346] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.958427] hub 8-0:1.0: USB hub found
[ 1.958435] hub 8-0:1.0: 2 ports detected
[ 2.164072] usb 1-2: new low-speed USB device number 2 using uhci_hcd
[ 2.270363] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.270380] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.270500] ata3.00: ATA-11: PNY CS900 120GB SSD, CS900613, max UDMA/133
[ 2.270502] ata3.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.270616] ata3.00: configured for UDMA/133
[ 2.270790] scsi 2:0:0:0: Direct-Access ATA PNY CS900 120GB 0613 PQ: 0 ANSI: 5
[ 2.276350] ata5: SATA link down (SStatus 4 SControl 300)
[ 2.278348] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.291381] ata4.00: ATAPI: TSSTcorp DVD+/-RW TS-L633C, DW40, max UDMA/100
[ 2.291384] ata4.00: applying bridge limits
[ 2.311571] ata4.00: configured for UDMA/100
[ 2.314478] scsi 3:0:0:0: CD-ROM TSSTcorp DVD+-RW TS-L633C DW40 PQ: 0 ANSI: 5
[ 2.345638] sd 2:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 2.345649] sd 2:0:0:0: [sda] Write Protect is off
[ 2.345651] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.345667] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.346241] sda: sda1
[ 2.346500] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.360746] usb 1-2: New USB device found, idVendor=413c, idProduct=2107
[ 2.360750] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.360753] usb 1-2: Product: Dell USB Entry Keyboard
[ 2.360755] usb 1-2: Manufacturer: DELL
[ 2.366697] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.383025] usbcore: registered new interface driver usbhid
[ 2.383026] usbhid: USB HID core driver
[ 2.383813] sr 3:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.383816] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.383942] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.384309] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.0/0003:413C:2107.0001/input/input3
[ 2.412077] usb 6-2: new full-speed USB device number 2 using uhci_hcd
[ 2.444250] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:1a.0-2/input0
[ 2.560093] tsc: Refined TSC clocksource calibration: 2393.999 MHz
[ 2.560101] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22821267f49, max_idle_ns: 440795240327 ns
[ 2.592123] [drm] ib test on ring 5 succeeded
[ 2.592423] [drm] Radeon Display Connectors
[ 2.592424] [drm] Connector 0:
[ 2.592425] [drm] VGA-1
[ 2.592427] [drm] DDC: 0x7e20 0x7e20 0x7e24 0x7e24 0x7e28 0x7e28 0x7e2c 0x7e2c
[ 2.592428] [drm] Encoders:
[ 2.592429] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 2.592430] [drm] Connector 1:
[ 2.592431] [drm] HDMI-A-1
[ 2.592432] [drm] HPD2
[ 2.592433] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 2.592434] [drm] Encoders:
[ 2.592435] [drm] DFP2: INTERNAL_UNIPHY1
[ 2.592436] [drm] Connector 2:
[ 2.592437] [drm] DVI-I-1
[ 2.592438] [drm] HPD1
[ 2.592439] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 2.592440] [drm] Encoders:
[ 2.592441] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 2.592442] [drm] DFP1: INTERNAL_UNIPHY
[ 2.617696] usb 6-2: New USB device found, idVendor=046d, idProduct=c52b
[ 2.617698] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.617700] usb 6-2: Product: USB Receiver
[ 2.617702] usb 6-2: Manufacturer: Logitech
[ 2.632035] logitech-djreceiver 0003:046D:C52B.0004: hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-2/input2
[ 2.647151] [drm] fb mappable at 0xE034D000
[ 2.647152] [drm] vram apper at 0xE0000000
[ 2.647153] [drm] size 7299072
[ 2.647154] [drm] fb depth is 24
[ 2.647155] [drm] pitch is 6912
[ 2.647224] fbcon: radeondrmfb (fb0) is primary device
[ 2.668697] Console: switching to colour frame buffer device 210x65
[ 2.672791] radeon 0000:01:00.0: fb0: radeondrmfb frame buffer device
[ 2.704808] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
[ 2.769760] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0004/0003:046D:4055.0005/input/input4
[ 2.769856] logitech-hidpp-device 0003:046D:4055.0005: input,hidraw2: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:1d.0-2:1
[ 2.771889] input: Logitech K520 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0004/0003:046D:2011.0006/input/input5
[ 2.772013] logitech-hidpp-device 0003:046D:2011.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech K520] on usb-0000:00:1d.0-2:2
[ 2.940093] usb 4-4: new high-speed USB device number 3 using ehci-pci
[ 3.153675] device-mapper: uevent: version 1.0.3
[ 3.153751] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 3.159231] usb 4-4: New USB device found, idVendor=0644, idProduct=0200
[ 3.159234] usb 4-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.159236] usb 4-4: Product: CA-200
[ 3.159238] usb 4-4: Manufacturer: TEAC
[ 3.159240] usb 4-4: SerialNumber: 000004239BB8
[ 3.162161] usb-storage 4-4:1.0: USB Mass Storage device detected
[ 3.166291] scsi host8: usb-storage 4-4:1.0
[ 3.166395] usbcore: registered new interface driver usb-storage
[ 3.166760] usbcore: registered new interface driver uas
[ 3.244316] random: plymouthd: uninitialized urandom read (8 bytes read)
[ 3.244459] random: plymouthd: uninitialized urandom read (8 bytes read)
[ 3.364118] raid6: sse2x1 gen() 4102 MB/s
[ 3.432101] raid6: sse2x1 xor() 4045 MB/s
[ 3.500102] raid6: sse2x2 gen() 4278 MB/s
[ 3.568093] raid6: sse2x2 xor() 4917 MB/s
[ 3.636094] raid6: sse2x4 gen() 7072 MB/s
[ 3.636096] clocksource: Switched to clocksource tsc
[ 3.700091] usb 8-1: new full-speed USB device number 2 using uhci_hcd
[ 3.704095] raid6: sse2x4 xor() 5612 MB/s
[ 3.704097] raid6: using algorithm sse2x4 gen() 7072 MB/s
[ 3.704098] raid6: .... xor() 5612 MB/s, rmw enabled
[ 3.704099] raid6: using ssse3x2 recovery algorithm
[ 3.705243] xor: measuring software checksum speed
[ 3.744092] prefetch64-sse: 8967.000 MB/sec
[ 3.784083] generic_sse: 7953.000 MB/sec
[ 3.784085] xor: using function: prefetch64-sse (8967.000 MB/sec)
[ 3.830039] Btrfs loaded, crc32c=crc32c-generic
[ 3.877368] usb 8-1: New USB device found, idVendor=10ce, idProduct=eb70
[ 3.877372] usb 8-1: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 3.877375] usb 8-1: Manufacturer: KTURT.LTD
[ 3.883818] hid-generic 0003:10CE:EB70.0007: hiddev1,hidraw4: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1d.2-1/input0
[ 4.202359] scsi 8:0:0:0: Direct-Access TEAC USB HS-CF Card 4.12 PQ: 0 ANSI: 0
[ 4.206214] scsi 8:0:0:1: Direct-Access TEAC USB HS-xD/SM 4.12 PQ: 0 ANSI: 0
[ 4.209721] scsi 8:0:0:2: Direct-Access TEAC USB HS-MS Card 4.12 PQ: 0 ANSI: 0
[ 4.212838] scsi 8:0:0:3: Direct-Access TEAC USB HS-SD Card 4.12 PQ: 0 ANSI: 0
[ 4.217979] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.456356] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 4.460974] sd 8:0:0:1: [sdc] Attached SCSI removable disk
[ 4.465590] sd 8:0:0:2: [sdd] Attached SCSI removable disk
[ 4.469341] sd 8:0:0:3: [sde] Attached SCSI removable disk
[ 4.619837] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.631584] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.648203] systemd[1]: Detected architecture x86-64.
[ 4.649077] systemd[1]: Set hostname to <mill-DIY>.
[ 4.726764] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.726768] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.787754] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.787972] systemd[1]: Created slice System Slice.
[ 4.788019] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.788087] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.788099] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.788161] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 4.788225] systemd[1]: Listening on udev Control Socket.
[ 4.788245] systemd[1]: Reached target System Time Synchronized.
[ 4.815486] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 4.825342] lp: driver loaded but no devices found
[ 4.829288] ppdev: user-space parallel port driver
[ 4.830592] parport_pc 00:02: reported by Plug and Play ACPI
[ 4.830645] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 4.914772] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k SSFS
[ 4.932236] lp0: using parport0 (interrupt-driven).
[ 4.936923] systemd-journald[341]: Received request to flush runtime journal from PID 1
[ 5.035969] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x000000000000082D (\GLBC) (20170728/utaddress-247)
[ 5.035977] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x000000000000082D (\GLBC) (20170728/utaddress-247)
[ 5.035982] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x000000000000082A-0x000000000000082A (\SACT) (20170728/utaddress-247)
[ 5.035986] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x000000000000082A-0x000000000000082A (\SACT) (20170728/utaddress-247)
[ 5.035990] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x0000000000000828 (\SSTS) (20170728/utaddress-247)
[ 5.035994] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x0000000000000828 (\SSTS) (20170728/utaddress-247)
[ 5.035999] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.036002] ACPI Warning: SystemIO range 0x00000000000008B0-0x00000000000008BF conflicts with OpRegion 0x00000000000008B8-0x00000000000008BB (\GIC2) (20170728/utaddress-247)
[ 5.036006] ACPI Warning: SystemIO range 0x00000000000008B0-0x00000000000008BF conflicts with OpRegion 0x00000000000008B8-0x00000000000008BB (\GIC2) (20170728/utaddress-247)
[ 5.036010] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.036011] ACPI Warning: SystemIO range 0x0000000000000880-0x00000000000008AF conflicts with OpRegion 0x000000000000088C-0x000000000000088F (\GIC1) (20170728/utaddress-247)
[ 5.036015] ACPI Warning: SystemIO range 0x0000000000000880-0x00000000000008AF conflicts with OpRegion 0x000000000000088C-0x000000000000088F (\GIC1) (20170728/utaddress-247)
[ 5.036020] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.036042] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 5.037120] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 5.037164] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 5.037218] sd 8:0:0:0: Attached scsi generic sg2 type 0
[ 5.037265] sd 8:0:0:1: Attached scsi generic sg3 type 0
[ 5.037604] sd 8:0:0:2: Attached scsi generic sg4 type 0
[ 5.037645] sd 8:0:0:3: Attached scsi generic sg5 type 0
[ 5.136535] coretemp coretemp.0: Using relative temperature scale!
[ 5.136553] coretemp coretemp.0: Using relative temperature scale!
[ 5.136581] coretemp coretemp.0: Using relative temperature scale!
[ 5.136608] coretemp coretemp.0: Using relative temperature scale!
[ 5.140469] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 5.258454] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
[ 5.626046] snd_hda_codec_analog hdaudioC0D2: autoconfig for AD1984A: line_outs=1 (0x12/0x0/0x0/0x0/0x0) type:line
[ 5.626050] snd_hda_codec_analog hdaudioC0D2: speaker_outs=1 (0x13/0x0/0x0/0x0/0x0)
[ 5.626052] snd_hda_codec_analog hdaudioC0D2: hp_outs=1 (0x11/0x0/0x0/0x0/0x0)
[ 5.626054] snd_hda_codec_analog hdaudioC0D2: mono: mono_out=0x0
[ 5.626056] snd_hda_codec_analog hdaudioC0D2: inputs:
[ 5.626058] snd_hda_codec_analog hdaudioC0D2: Mic=0x14
[ 5.626060] snd_hda_codec_analog hdaudioC0D2: Line=0x15
[ 5.638832] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 5.639074] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 5.639137] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 5.639188] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 5.640222] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 5.845999] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 6.052294] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 7.540962] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 7.541070] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
[ 7.541103] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s25: link becomes ready
[ 8.935697] fuse init (API version 7.26)
[ 51.197667] random: crng init done
[ 51.197670] random: 5 urandom warning(s) missed due to ratelimiting
[ 85.507125] I-pipe: head domain RTAI registered.
[ 85.507128] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 85.507131] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 16624799, CLOCK NAME: 'tsc', CLOCK FREQ: 2393826000, CPU FREQ: 2393826000, LINUX TIMER IRQ: 4355.
[ 85.514933] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 85.514963] kstacks pool size = 524288 bytes
[ 85.514964] RTAI[sched]: hard timer type/freq = lapic/16624799(Hz)
[ 85.514966] linear timed lists.
[ 85.514967] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393826000 hz.
[ 85.514969] RTAI[sched]: timer setup = 60 ns, resched latency = 0 ns.
[ 85.527348] USERMODE CHECK: OK.
[ 85.527351] USERMODE CHECK PROVIDED (ns): KernelLatency -1, UserLatency -1.
mill@mill-DIY:~$ Please Log in or Create an account to join the conversation.
- Thank you received: 4652
07 Jan 2020 22:15 #154264
Replied by andypugh on topic Realtime system did not load. insmod: ERROR: could not insert module /usr/realti
Did you get anywhere with this?
- LinuxCNC
- General LinuxCNC Questions
- Realtime system did not load. insmod: ERROR: could not insert module /usr/realti
Time to create page: 0.230 seconds
