I need help with a gofab cnc table
- Warrenh
27 Dec 2019 15:39 #153289
by Warrenh
I need help with a gofab cnc table was created by Warrenh
I bought a gofab CNC table and it is working but there are many things that are not as they should be. They promise free updates for life but there have been none for a year. The main issue I have is not being able to back up in the instance of a problem in the cut. The only way to fix is to replay the file from the beginning without the torch firing then pause and turn on the torch and start again. Not a problem on a 5 minute file but on a 45 minute cut with a problem in the last 5 minutes it sucks. Is there a way to move to a better solution without them. I know nothing about the programming. Any advice would be welcomed.
- Thank you received: 7468
27 Dec 2019 16:43 #153293
Replied by tommylight on topic I need help with a gofab cnc table
Time to create page: 0.087 seconds
