OK so I've decided to go with 2.8
I have :-
Debian GNU / Linux, with linux 3.4-9-rati -686- pae
Grub Version 1.99-27+ deb7u3
and Linux cnc 2.8
Replied by captain chaos on topic Stepper enable?
I can't seem to get the Charge pump to work
Is "External Enable" Estop in or Digital in 0 (Digital in has 0,1,2 and 3)
Break out Board Pin Assignments and Step Conf images included
I'm using step config XY,UV foam to build a 4 joint XXYZ gantry router
Next question would be how do I split XY, UV to be X linked to joint U as it is and split V from Y to make it V=Z
This looks like a long hard slog, so should maybe move the topic to something like "Par Port Stepper Gantry XXYZ"
Chers Paul
Additionally to the above I tried to set up the parallel port tester and got the following error :-
chaos@gantry:~/Desktop$ halrun -I -f ptest.hal
halrun: Realtime already running. Use 'halrun -U' to stop existing realtime session.
chaos@gantry:~/Desktop$ halrun -U
Could not open command file 'ptest.hal'
halcmd: exit
halcmd: exit
RTAPI: ERROR: could not open shared memory (No such file or directory)
ERROR: rtapi init failed
HALCMD: Release Mutex failed!
HAL: ERROR: could not initialize RTAPI
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Error: Module hal_lib is not currently loaded
Error: Module rtapi is not currently loaded
Error: Module rtai_math is not currently loaded
Error: Module rtai_sched is not currently loaded
Error: Module rtai_hal is not currently loaded
Looks like I need to load the 'rtapi' kernel as opposed to the 3.4-9-rati that I have
if so how do I go about this
can anyone point me in the right direction please
Cheers Paul
