having problems to update
- flexbex
- Thank you received: 3
28 Jan 2020 03:46 #155974
by flexbex
having problems to update was created by flexbex
Running linuxcnc wheezy 2.7. Freshly installed from the website.
when using sudo apt-get update I am getting the error
Before I also had an error with
but fixed it with adding a file to /etc/apt/apt.conf.d
file: 10no-valid-until
text: Acquire::Check-Valid-Until "0";
I also get an error when using find best server it tells me that there is no suitable server.
W: Failed to fetch http://http.us.debian.org/debian/dists/wheezy/contrib/binary-i386/Packages 404 Not Found [IP: 64.50.236.52 80]
W: Failed to fetch http://http.us.debian.org/debian/dists/wheezy/non-free/binary-i386/Packages 404 Not Found [IP: 64.50.236.52 80]
W: Failed to fetch http://http.us.debian.org/debian/dists/wheezy/main/binary-i386/Packages 404 Not Found [IP: 64.50.236.52 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/main/source/Sources 404 Not Found [IP: 130.89.148.13 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/contrib/source/Sources 404 Not Found [IP: 130.89.148.13 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/non-free/source/Sources 404 Not Found [IP: 130.89.148.13 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/main/binary-i386/Packages 404 Not Found [IP: 130.89.148.13 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/contrib/binary-i386/Packages 404 Not Found [IP: 130.89.148.13 80]
W: Failed to fetch http://archive.debian.org/debian/dists/wheezy/updates/non-free/binary-i386/Packages 404 Not Found [IP: 130.89.148.13 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.Before I also had an error with
Release file for http://archive.debian.org/debian-security/dists/wheezy/updates/Release is expiredbut fixed it with adding a file to /etc/apt/apt.conf.d
The following user(s) said Thank You: yamaplos
- BeagleBrainz
- Visitor
28 Jan 2020 05:00 #155975
by BeagleBrainz
Replied by BeagleBrainz on topic having problems to update
Answer is here
forum.linuxcnc.org/38-general-linuxcnc-q...itory-expired#155502
Note which lines have been commented out
- Thank you received: 4652
06 Feb 2020 14:46 #156637
Replied by andypugh on topic having problems to update
It seems that the problem might be that the selected mirror does not mirror the archive versions.
I strongly suggest at least trying the Debian 9 / Stretch uspace version of LinuxCNC if doing a fresh install.
www.linuxcnc.org/downloads/
- yamaplos
13 May 2020 01:29 #167592
by yamaplos
Replied by yamaplos on topic having problems to update
@flexbex
You are now my favorite geek of all time. The 10no-valid-until file did the trick of passing the Release is expired (or so it seems),
I have now been able FINALLY to install Geany
In the name of all silly, why does LinuxCNC pack all of Libreoffice but NO decent plain text editor?
Anyway, much gratitude to LinuxCNC developers, even so. Having much fun.
I might even be able to fix a few more things that I had learned to live with.
Thank you again. Hope your problem gets solved also.
- BeagleBrainz
- Visitor
13 May 2020 01:52 #167593
by BeagleBrainz
There is also a remastered Mint 19.2 version that has Linuxcnc installed & geany, as that's my 2nd favourite text editor....I kinda prefer the editor that comes with midnight commander for general use.
