Backlash not working
11 Mar 2020 06:29 #159749 by NKeller
Backlash not working was created by NKeller
HI Guys
Im very new to linux CNC i just converted one of my milling machines with steppers and linux CNC :)
but i'm having a problem the backlash its not working.
I can see the correction value in the HAL meter but the stepper motor is not responding to the backlash
I have attached the HAL and INI files
Thank you
Nick
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
11 Mar 2020 07:21 - 11 Mar 2020 07:26 #159750 by BeagleBrainz
Replied by BeagleBrainz on topic Backlash not working
Maybe this [AXIS_1]
TYPE = LINEAR
HOME = -0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 50
MAX_ACCELERATION = 70
STEPGEN_MAXVEL = 70
STEPGEN_MAXACCEL = 110
The docs say 1.5 to 2.0 times.
But there is a good chance I've not it right
Last edit: 11 Mar 2020 07:26 by BeagleBrainz.
11 Mar 2020 07:24 #159752 by NKeller
Replied by NKeller on topic Backlash not working
i have tried making it larger up too 240
  • BeagleBrainz
  • Visitor
  • Visitor
11 Mar 2020 07:27 - 11 Mar 2020 07:31 #159753 by BeagleBrainz
How are you checking for backlash ?
Is that right for FERROR ?
Last edit: 11 Mar 2020 07:31 by BeagleBrainz.
11 Mar 2020 07:30 #159754 by NKeller
so i'm moving the machine 2mm positive and 1mm negative and its leaving a difference
it seems like the stepper is not moving at all to compensate for the backlash
11 Mar 2020 07:35 #159755 by NKeller
im not sure what you mean by
  • BeagleBrainz
  • Visitor
  • Visitor
11 Mar 2020 07:35 #159756 by BeagleBrainz
Before you are moving positive 2mm have you moved forward before that to take up any existing backlash in the positive direction ?
11 Mar 2020 07:37 #159757 by NKeller
yes i have :)
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
11 Mar 2020 07:41 #159758 by BeagleBrainz
The value ?
11 Mar 2020 07:42 #159759 by NKeller
10
Time to create page: 0.319 seconds
