Backlash not working
- NKeller
11 Mar 2020 06:29 #159749
by NKeller
Backlash not working was created by NKeller
HI Guys
Im very new to linux CNC i just converted one of my milling machines with steppers and linux CNC
but i'm having a problem the backlash its not working.
I can see the correction value in the HAL meter but the stepper motor is not responding to the backlash
I have attached the HAL and INI files
Thank you
Nick
Thank you
Nick
- BeagleBrainz
- Visitor
11 Mar 2020 07:21 - 11 Mar 2020 07:26 #159750
by BeagleBrainz
Replied by BeagleBrainz on topic Backlash not working
Maybe this [AXIS_1]
TYPE = LINEAR
HOME = -0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 50
MAX_ACCELERATION = 70
STEPGEN_MAXVEL = 70
STEPGEN_MAXACCEL = 110
The docs say 1.5 to 2.0 times.
But there is a good chance I've not it right
TYPE = LINEAR
HOME = -0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 50
STEPGEN_MAXVEL = 70
Last edit: 11 Mar 2020 07:26 by BeagleBrainz.
- NKeller
11 Mar 2020 07:24 #159752
by NKeller
Replied by NKeller on topic Backlash not working
i have tried making it larger up too 240
- BeagleBrainz
- Visitor
11 Mar 2020 07:27 - 11 Mar 2020 07:31 #159753
by BeagleBrainz
How are you checking for backlash ?
Is that right for FERROR ?
Last edit: 11 Mar 2020 07:31 by BeagleBrainz.
- NKeller
11 Mar 2020 07:30 #159754
by NKeller
so i'm moving the machine 2mm positive and 1mm negative and its leaving a difference
it seems like the stepper is not moving at all to compensate for the backlash
- NKeller
11 Mar 2020 07:35 #159755
by NKeller
im not sure what you mean by
- BeagleBrainz
- Visitor
11 Mar 2020 07:35 #159756
by BeagleBrainz
Before you are moving positive 2mm have you moved forward before that to take up any existing backlash in the positive direction ?
- NKeller
11 Mar 2020 07:37 #159757
by NKeller
yes i have
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Visitor
11 Mar 2020 07:41 #159758
by BeagleBrainz
The value ?
The value ?
- NKeller
11 Mar 2020 07:42 #159759
by NKeller
10
Time to create page: 0.173 seconds
