I Need help for 4 axis cnc
25 Mar 2020 14:40 #161441 by Endless
I Need help for 4 axis cnc was created by Endless
Hi
Hello friends, I just joined the forum now.I designed a cnc router and chassis production is finished. I am currently installing the electronics. Router dimensions y 2800mm x1450 mm z450mm
Standard 3 axis cnc router In addition I have the 4th axis that can rotate 360 ??degrees.this axis will turn 90-180-270-360 degrees.consider a wood panel spindle holes in the surface and side hole in 4.axis .My axis motors nema 34 12nm stepper.I haven't bought a cnc control board or control panel yet.this is my first cnc router and my knowledge is very little.
I have no knowledge of software.i use autocad 3d max solidwoks very well but i don't have cam knowledge.
If you help me in this matter, you will make me very happy
Thanks in advance to everyone for help
25 Mar 2020 14:56 #161446 by cmorley
Replied by cmorley on topic I Need help for 4 axis cnc
What interface hardware are you planing to use?
Chris
25 Mar 2020 15:06 #161451 by Endless
Replied by Endless on topic I Need help for 4 axis cnc
Sorry ı dont understand this question. Are you talking about the cnc control board?
25 Mar 2020 15:10 #161453 by cmorley
Yes like parallel port or Mesa cards. that kind of motor drives step and direction or servo.
Chris
25 Mar 2020 15:16 #161455 by Endless
ı use 12nm stepper motor. I planning paralel port cnc controller. This product = urun.n11.com/sigorta-kutulari-ve-elektri...s_D_BwE&gclsrc=aw.ds
I live in Turkey. there is no sale of mesa cards here
25 Mar 2020 15:27 #161458 by cmorley
Ok great. There is even an image of linuxcnc's Gmoccapy interface on that page :)
For a parallel port based machine you would usually use stepconf to set up the basic machine.
linuxcnc.org/docs/2.7/html/config/stepconf.html
Chris
25 Mar 2020 15:44 #161463 by Endless
thank you for your interest. Will it be necessary to write a post processor according to the CAM program to be used? I do not know how to do this, I do not know how
25 Mar 2020 15:57 #161467 by cmorley
Depends on the cam program. Some have linuxcnc or Mach post processors and a general Fanuk post processor should get you close for plain gcode programs.
25 Mar 2020 16:12 #161468 by Endless
Did you look at the pictures in my first message?
my machine is not a standard machine
26 Mar 2020 11:34 #161553 by cmorley
Ahh yes - the second head is a little non standard
What does it do?
Time to create page: 0.124 seconds
