I Need help for 4 axis cnc
- Thank you received: 7478
26 Mar 2020 13:21 #161563
Replied by tommylight on topic I Need help for 4 axis cnc
As far as i can tell from that drawings, it is a dual drill setup with 90 degree rotation.
- bbsr_5a
- Thank you received: 106
26 Mar 2020 18:23 #161592
by bbsr_5a
Replied by bbsr_5a on topic I Need help for 4 axis cnc
Hi
solidcan has a 4th axis post for Fanuc11m that will shure fit your need
if not licenced you simply can use a Free Autodesk product for small busines
the 4th axis is only a setup
i mainly use them as a B axis as the Y is then the main axis and the machine dont move in X Gantry
its basicly a lathe type machine 3Axis YZB with X takeng the center pont wherever 4th axis is located at the large Table
- Endless
26 Mar 2020 23:53 #161636
by Endless
Please watch video... with this machine I want to make holes on the 4 sides of the wooden panel. I don't want to simulate. just turn 90 - 180 - 270 - 360 degree enough for me
Replied by Endless on topic I Need help for 4 axis cnc
27 Mar 2020 00:39 #161644
bilmem turkce abey !
That explains the workings nicely, should not be hard to do, i am sure we have done much more complicated stuff with Linuxcnc.
- Thank you received: 2181
27 Mar 2020 23:00 #161765
Replied by cmorley on topic I Need help for 4 axis cnc
To my thinking it depends how you need to use the drill.
One way would be that the drill is completely independently controlled in the z axis -basically meaning you have two z axis. (maybe z and w?)
The second is that the drill when used is always use fully extended and you use the main z axis to set it's drill height.
You position the drill (extend / rotate) using HAL and then it's just tool offsets.
Andy is usually good at thinking these things through in smart ways.
Chris
Chris
- Thank you received: 4654
28 Mar 2020 21:57 #161846
Replied by andypugh on topic I Need help for 4 axis cnc
Custom kinematics and drilling in the W axis might be a way to go.
Though it would be possible to use coordinate-system rotation so that the drill moves are straight X (or Y, if you prefer)
Imagine drilling a hole at 45 degrees, and assuming that the rotary axis is C.
G0 C45
G10 L2 R45 (rotate the XY axes about Z)
G1 F20 X100 (drill a hole at 45 degrees)
G0 C45
- Endless
03 Apr 2020 23:27 #162618
by Endless
I have no information about what you say. because this is my first cnc machine. Will a post process be required for the CAM program? I don't even know this... please someone guide me. I would be very happy if he tells me what to do step by step...
I do not want the machine to work simultaneously. just turn the axis 90-180-270-360 in the video and drill the hole
Please help
Please help
- Endless
03 Apr 2020 23:31 #162619
by Endless
Thanks for answer but ı dont know HAL
- bbsr_5a
04 Apr 2020 07:16 #162646
by bbsr_5a
all you need to know in first hand is that it will work with linuxcnc so you can start to build
the postprocess is your Word/Notpad or as you are on linux GEDIT to change your axis 0-90-180-270 by adding the command
your CAM and Post works flat out
the 2 Tools will have diferent coordinate system G54 G55 they arte on so the offset is non problem
the Z is for the First tool
the w for the Second
if it is only this 2 tools not a 11head machine it is far easyser then you think
- Thank you received: 4149
04 Apr 2020 10:36 #162666
Replied by rodw on topic I Need help for 4 axis cnc
you will by the time you build this machineThanks for answer but ı dont know HAL
Time to create page: 0.129 seconds
