Getting joint 0 following error?
- Thank you received: 5321
29 Mar 2020 00:56 #161897
Replied by PCW on topic Getting joint 0 following error?
You could set ferror and min_ferror to say 1 while testing and tuning
The following user(s) said Thank You: Catch22
- Catch22
- Thank you received: 17
29 Mar 2020 01:04 #161899
by Catch22
Replied by Catch22 on topic Getting joint 0 following error?
I will give that a try, thanks again.
- Thank you received: 4652
29 Mar 2020 14:00 #161969
Replied by andypugh on topic Getting joint 0 following error?
You might also want to remove all the lines like:
net y-vel-cmd => pid.y.command-deriv
I don't think that is the problem, but there is an issue with connecting an empty signal to that pin in some versions of LinuxCNC.
- Catch22
29 Mar 2020 14:48 #161972
by Catch22
So would I delete all of this?
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
29 Mar 2020 14:53 #161973
No!
just
net x-vel-cmd => pid.x.command-deriv
net z-vel-cmd => pid.z.command-deriv
just
- Catch22
29 Mar 2020 15:06 #161975
by Catch22
Ok thanks
- OT-CNC
- Thank you received: 75
29 Mar 2020 17:50 #162009
by OT-CNC
Replied by OT-CNC on topic Getting joint 0 following error?
I'm working with the same drives right now and linear encoders on the machine. How did you setup the drives? Are they running the motors correctly (belts removed) before connecting to linuxcnc?
- Catch22
29 Mar 2020 18:33 #162012
by Catch22
Only one motor is working properly, when I get a few minutes I will let you know how they are wired, after I get it working properly.
- OT-CNC
29 Mar 2020 19:01 #162015
by OT-CNC
I'm almost all set with the initial setup on mine. Let me know if you have questions. I would make sure they run correctly with a small external control voltage applied, like 1.5v from a battery, before connecting to linuxcnc. I was initially fighting duds from fleabay. Motors should run smooth in both directions and drives should not fault out.
- Catch22
29 Mar 2020 20:49 #162021
by Catch22
Ok, so I tried 2 other drives that I had and all motors are turning both directions now.
I tried just manually moving each axis and x does nothing, y moves -.0003 and z moves -.0003 nomatter how far I move them that's it.
Time to create page: 0.290 seconds
