Getting joint 0 following error?
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
29 Mar 2020 20:52 #162022 by Catch22
Replied by Catch22 on topic Getting joint 0 following error?
Are you also using 7i77 Mesa card?
29 Mar 2020 20:57 #162023 by PCW
Replied by PCW on topic Getting joint 0 following error?
Ok, so I tried 2 other drives that I had and all motors are turning both directions now.
I tried just manually moving each axis and x does nothing, y moves -.0003 and z moves -.0003 nomatter how far I move them that's it.
Are you saying the scales are not reading correctly?
Are the 7I77 encoder mode jumpers set to match the interface type (differential or TTL)?
The following user(s) said Thank You: Catch22
  • Catch22
  • Elite Member
  • Elite Member
29 Mar 2020 21:35 #162026 by Catch22
Not sure what they are, anilam A10 linear scales, and as for jumpers, I haven't set any.
29 Mar 2020 21:39 #162027 by PCW
If the encoder jumpers are set for differential mode (the default) and you have
single ended encoders (common on older machines) the encoder inputs will not work
How many wires do your encoders have?
  • Catch22
  • Elite Member
  • Elite Member
29 Mar 2020 21:42 #162029 by Catch22
Ok they are TTL and the resolution is .0004 .
29 Mar 2020 22:06 #162033 by PCW
OK so those will not work unless you jumper the 7I77 encoder inputs for TTL mode
(scale would be 2500.00)
  • Catch22
  • Elite Member
  • Elite Member
29 Mar 2020 22:06 #162034 by Catch22
It looks like 2 wires a clear and black in the control panel.
  • Catch22
  • Elite Member
  • Elite Member
29 Mar 2020 22:08 #162035 by Catch22
When you say jumper, are you referring to moving one of the jumpers or something else?
29 Mar 2020 22:13 #162036 by PCW
Yes, you must set the encoder mode jumpers on the 7I77 to match your encoder type
(page 3 in the 7I77 manual)
29 Mar 2020 23:22 #162040 by OT-CNC
Replied by OT-CNC on topic Getting joint 0 following error?
Old Anilam crusader?? If so, double check the black and clear coming from the motor connectors are the tach feedback. I don't remember the color of the encoder wires. They may be black and clear also? If it's a BP type knee mill, they come out of a separate harness.
Yes I'm using the 7i77 too.
