Plasmac ERROR "Plasmac: already exists"
- Thank you received: 4144
16 Apr 2020 20:07 - 16 Apr 2020 20:07 #164201
Replied by rodw on topic Plasmac ERROR "Plasmac: already exists"
Sometimes plasmac seems to have a mind of its own when probing. It should not go to maxZ but it will if it sees the probe trigger before it expects it to recover. But it should raise an error window. Here is an example once I got probing dialed in....
I'lll let Phill chime in about the settings so if the screen dumps are no longer current, refresh them for him.
Last edit: 16 Apr 2020 20:07 by rodw.
The following user(s) said Thank You: sharp_reaper
- phillc54
- Thank you received: 2100
17 Apr 2020 00:39 #164214
by phillc54
Replied by phillc54 on topic Plasmac ERROR "Plasmac: already exists"
You have Safe Height of 20 and Probe Height of 38.
It will got to Safe Height to move to the next cut but then move up to Probe Height to probe for the next cut.
You should have Probe Height set to less than or equal to Safe Height.
Although that does look like it is going higher than 38, is that still correct for Probe Height.
- sharp_reaper
- Thank you received: 7
08 Jun 2020 10:15 #170612
by sharp_reaper
Replied by sharp_reaper on topic Plasmac ERROR "Plasmac: already exists"
It is working fine thank you for your help, Rod and Phill.
Time to create page: 0.093 seconds
