Pendant WHB04B on LinuxCNC 2.7 / Debian
6 years 6 months ago #163097 by Peterdeleu
Same problem.
I've changed the ATTR to eb93 myself a few hours ago.
I saw in the results of lsusb that it had to be eb63
6 years 6 months ago - 6 years 6 months ago #163104 by alkabal
At the end you ATTR is eb63 ? (not eb93)
if this is eb63 please try this binaries (edit : removed)
Or maybee is needed to do in the binaires folder : sudo chmod +x xhc-whb04b-6
The driver is only tested with 6 axis version.
Last edit: 6 years 6 months ago by alkabal.
6 years 6 months ago #163111 by Peterdeleu
I moved a step forward after "sudo chmod +x xhc-whb04b-6 "
But another error message now
6 years 6 months ago #163118 by tommylight
There is a missing bracket on the first line of xhc-whb04b-6 file.
6 years 6 months ago #163120 by Peterdeleu
You mean the file in the binary folder?
I can't edit this file. It is not a text file .
6 years 6 months ago - 6 years 6 months ago #163137 by MovT
Peter.
If you have LinuxCNC 2.9 installed follow Talla83's video and use the driver he supplied in the video, if you understand German and you get the MPG running fine.
I have the XHC-WHB04B-6 running with this diver. There is one trap i can tell ou the solution if u are running in. If you try it in a fresh installation of LCNC 2.9 you will not get any errors.
Best,
Udo
Last edit: 6 years 6 months ago by MovT.
Time to create page: 0.186 seconds
