Pendant WHB04B on LinuxCNC 2.7 / Debian
6 years 6 months ago - 6 years 6 months ago #163149 by alkabal
Attached latest binaries + exemple config for 6 axis version tested and used all this evening.
Last edit: 6 years 6 months ago by alkabal.
6 years 6 months ago #163163 by Peterdeleu
Still an error message :(
6 years 6 months ago #163167 by Peterdeleu
I run LinuxCNC on a virtual machine. (for testing purposes, not connected to a CNC machine), so I'm able to revert to a snapshot that holds a fresh installation.
German is not an issue, I've tried the Talla83 video earlier, with a LCNC 2.7 without succes. Maybe it works better on version 2.9. But my production machine is running 2.7, and I'm afraid that a simple upgrade from 2.7 to 2.9 will give me other issues.
If the Alkabal solution doesn't work, I'll try the Talla83 solution once again.
6 years 6 months ago #163169 by MovT
The thing you need to change is the axis to joint conversion when you change from 2.7 to >2.7. This is a step i have done at first i started on LinuxCNC a few weeks ago. The change is worth it.
I can give you assistance for setting up the wheel on LCNC 2.8 or 2.9. I am on Discord on the #Hazzy server.
Best,
Udo
6 years 6 months ago #163177 by Peterdeleu
I tried to follow the Talla83 solution
During the command : ./configure --with-realtime=uspace it stops with this error message
6 years 6 months ago - 6 years 6 months ago #163179 by Peterdeleu
Maybe I should give up :)
I've installed giblib2.0, gtk2.0, yapps2, intltool and tcl.h
It seems like I miss a lot of things here..
It is not easy with lack of Linux knowledge :)
Now it stuks on : see error message
Last edit: 6 years 6 months ago by Peterdeleu.
Time to create page: 0.338 seconds
