Axis went no where after the end of cycle
- Dinuka_Shehan
- Thank you received: 26
11 Apr 2020 12:15 - 11 Apr 2020 12:15 #163598
by Dinuka_Shehan
Axis went no where after the end of cycle was created by Dinuka_Shehan
after end of all axis travel to weird location.
is this G54 error?
please help
is this G54 error?
please help
Last edit: 11 Apr 2020 12:15 by Dinuka_Shehan.
- Thank you received: 7468
11 Apr 2020 13:34 #163608
Replied by tommylight on topic Axis went no where after the end of cycle
That looks like a gcode error, not Linuxcnc error.
Attach the gcode. And remove the tool 7 from gcode as you do not have it in the tool table, or add it to tool table.
- bbsr_5a
- Thank you received: 106
11 Apr 2020 14:17 #163616
by bbsr_5a
Replied by bbsr_5a on topic Axis went no where after the end of cycle
hi you need to home the machine to a point so it knows also where is the max to go
please get you at least 2 simple switches to do a basic machine homing
and do not use G53 moves to the end to get free running
just pull back x as it seams to be a Lathe Machine
- Dinuka_Shehan
14 Apr 2020 09:32 #163932
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Axis went no where after the end of cycle
i have using input 4 input pins
Estop
Index
Phase A
Phase B for quadrature encoder.
I can only use home or limit switch.not both of them.
Phase B not working because when threading i turn spindle by hand(right hand thread) Z axis moving but i turn reverse direction Z axis not moving.
Estop
Index
Phase A
- Dinuka_Shehan
14 Apr 2020 09:36 #163933
by Dinuka_Shehan
How to cancel G53 moves.i am using subroutines
Yes it is a lathe.hi you need to home the machine to a point so it knows also where is the max to go
- bbsr_5a
14 Apr 2020 11:29 #163934
by bbsr_5a
the G53 moves are canceld inside your postprocessor
the cam can be edited in all Systems to not output the moves at start or at end
- Thank you received: 2175
14 Apr 2020 16:48 - 14 Apr 2020 16:48 #163964
It's possible to do limits and homing on one pin.
AFAIK moving the spindle backwards will not move the axis backwards, lathe threading is not made to do that. It moves only in one direction.
You don't need to cancel G53 they are not modal
Replied by cmorley on topic Axis went no where after the end of cycle
Estop
Index
Phase A
Last edit: 14 Apr 2020 16:48 by cmorley.
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
15 Apr 2020 02:59 #164006
by Dinuka_Shehan
how to change the machine home position?
End of the cycle always going +X on axis it is weird.you can see it with screenshot
15 Apr 2020 03:01 #164007
without the gcode program it's hard to say.
- Dinuka_Shehan
15 Apr 2020 03:07 #164008
by Dinuka_Shehan
it is face subroutine of BigjohnT
Time to create page: 0.121 seconds
