Axis went no where after the end of cycle
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
15 Apr 2020 03:08 #164009 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Axis went no where after the end of cycle
without the gcode program it's hard to say.
(info: Facing)
; TOUCH OFF Z zero FIRST
; variable 5410 is the current tool tip diameter so make sure
; your tool table is set correctly...
o<face>sub
#<stock-diameter> = #1 (=1.000 Stock Diameter)
#<cut-depth> = #2 (=0.010 Cut Depth)
#<start-z> = #3 (=0.000 Start Z)
#<end-z> = #4 (=-0.020 End Z)
#<sfm> = #5 (=80 SFM)
#<tool> = #6 (=1 Tool)
#<max-rpm> = #7 (=2000 Max RPM)
#<feed-rate> = #8 (=2 Feed IPM)
#<coolant>= #9 (=8 Coolant 8 On 9 Off)
#<setZzero>= #10 (=0 Set Z0 0=No 1=Yes)
; SETUP TOOL
G18
T#<tool> M6
G43
G7 G96 D#<max-rpm> S#<sfm>
F#<feed-rate>
M3 M#<coolant>
#<inital-z> = [#<start-z>+0.050]
G0 X[#<stock-diameter>+0.050] Z[#<inital-z>]
#<current-z> = #<start-z>
o100 while[#<current-z> gt #<end-z>]
o101 if[#<current-z>-#<cut-depth> gt #<end-z>]
#<current-z> = [#<current-z>-#<cut-depth>]
o101 else
#<current-z> = #<end-z>
o101 endif
Z[#<current-z>]
G1 X-[#5410*3]
Z[#<current-z>+#5410+#5410]
G0 X[#<stock-diameter>+0.05]
o100 endwhile
M5 M9
; set Z zero to end of stock
o110 if [#<setZzero> EQ 1]
G0 Z[#<current-z>]
G10 L20 P1 Z0.000
G4P1.0
(MSG,Z Zero Set To Face)
o110 endif
G53 G0 X0 Z0
G97
o<face>endsub
15 Apr 2020 03:16 #164010 by cmorley
Replied by cmorley on topic Axis went no where after the end of cycle
well the program resets Z on G54 system at the end. which is probably fine and then
moves to G53 X0 Z0
Where is X0 Z0 in machine coordinates?
Machine coordinates are defined by entries in the INI and can really be anything.
It's strange to me that Big John chose to use G53 as It's not dependable from machine to machine where it is.
So my educated guess is that g53 x0 y0 is not where you hoped it is.
Chris
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
15 Apr 2020 03:18 - 15 Apr 2020 03:19 #164011 by Dinuka_Shehan
Last edit: 15 Apr 2020 03:19 by Dinuka_Shehan.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
15 Apr 2020 03:22 #164012 by Dinuka_Shehan
G53 zero and machine zero should be same?
What is the machine zero in ini file.i want change it.
Second one is how cancel current G54 position.
15 Apr 2020 03:31 #164013 by cmorley
G53 zero is the same as machine zero yes.
G53 is the Gcode that tells linuxcnc to use machine coordinates.
Machine zero is defined by homing and soft limits.
This isn't a one line change.
Personally I would change the subroutine to move somewhere relative to G54.
15 Apr 2020 07:16 #164025 by bbsr_5a
Replied by bbsr_5a on topic Axis went no where after the end of cycle
the subroutine i sent equip t with safe height moves
first move shout always be to safe height on a Tool measure start it may be below part
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
16 Apr 2020 17:13 #164166 by Dinuka_Shehan
Are you pl7i92;german plasma guy???
  • Moderator
  • Moderator
16 Apr 2020 17:44 #164174 by tommylight
Replied by tommylight on topic Axis went no where after the end of cycle
I think he is, but he has a new account.
Time to create page: 0.499 seconds
