To get ping time shorter
- Clive S
- Thank you received: 486
15 May 2020 12:52 #167835
by Clive S
To get ping time shorter was created by Clive S
I have forgotten which file to amend to add this :-
auto eth1
iface eth1 inet static
address 10.10.10.11
or dose it need only this:-
hardware−irq−coalesce−rx−usecs 0
auto eth1
address 10.10.10.11
- Thank you received: 5320
15 May 2020 13:12 - 15 May 2020 13:17 #167836
Replied by PCW on topic To get ping time shorter
That is the
/etc/network/interfaces
file
Is only needed if the Ethernet interface used (eth1 in this example)
supports irq coalescing. Intel Ethernet chips are the most common
devices that require this setting,
file
Last edit: 15 May 2020 13:17 by PCW.
- Clive S
15 May 2020 14:26 #167847
by Clive S
cnc@cnc-machine:~/Desktop$ dmesg | grep -i eth
[ 3.021927] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:19:d1:e3:f0:02
[ 3.021931] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.021952] e1000e 0000:00:19.0 eth0: MAC: 6, PHY: 6, PBA No: FFFFFF-0FF
[ 3.029430] e1000e 0000:00:19.0 enp0s25: renamed from eth0
this is what I have in :- /etc/network/interfaces
auto lo
iface lo inet loopback
Where do I put enp0s25 in the file
Replied by Clive S on topic To get ping time shorter
Re:-That is the
file
auto lo
- Thank you received: 7466
15 May 2020 14:45 #167848
Replied by tommylight on topic To get ping time shorter
No need if you have configured network through GUI.Where do I put enp0s25 in the file
15 May 2020 14:58 - 15 May 2020 15:00 #167849
auto lo
auto enp0s25
iface enp0s25 inet static
address 10.10.10.11
auto enp0s25
address 10.10.10.11
Last edit: 15 May 2020 15:00 by PCW.
15 May 2020 14:59 #167851
You cannot configure things like irq coalescing options via the GUI
15 May 2020 15:18 #167855
I said network, he already has coalescing where it belongs.
15 May 2020 15:28 #167856
Hardware driver settings are per device so should be in the interfaces file
under the specific device (enp0s25 in this case) you are configuring,
so no, he did not have it set properly
- Clive S
15 May 2020 16:24 #167864
by Clive S
I now have this in the file
auto lo
auto enp0s25
address 10.10.10.11
I also rebooted the pc. but not it did not bring the ping time down.
It does if I just put - sudo ethtool -C enp0s25 rx-usecs 0 -in a terminal but then it dose not save it upon reboot
auto lo
auto enp0s25
address 10.10.10.11
auto lo
auto enp0s25
address 10.10.10.11
15 May 2020 16:31 #167865
It looks like the
hardware-irq-coalesce-rx-usecs 0
text is corrupted (wrong dash symbol)
Time to create page: 0.134 seconds
