To get ping time shorter
15 May 2020 12:52 #167835 by Clive S
To get ping time shorter was created by Clive S
I have forgotten which file to amend to add this :-
auto eth1
iface eth1 inet static
address 10.10.10.11
or dose it need only this:-
hardware−irq−coalesce−rx−usecs 0
15 May 2020 13:12 - 15 May 2020 13:17 #167836 by PCW
Replied by PCW on topic To get ping time shorter
That is the
/etc/network/interfaces
file
Is only needed if the Ethernet interface used (eth1 in this example)
supports irq coalescing. Intel Ethernet chips are the most common
devices that require this setting,
Last edit: 15 May 2020 13:17 by PCW.
15 May 2020 14:26 #167847 by Clive S
Replied by Clive S on topic To get ping time shorter
That is the
file
Re:-
cnc@cnc-machine:~/Desktop$ dmesg | grep -i eth
[ 3.021927] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:19:d1:e3:f0:02
[ 3.021931] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.021952] e1000e 0000:00:19.0 eth0: MAC: 6, PHY: 6, PBA No: FFFFFF-0FF
[ 3.029430] e1000e 0000:00:19.0 enp0s25: renamed from eth0
this is what I have in :- /etc/network/interfaces
auto lo
iface lo inet loopback
Where do I put enp0s25 in the file
  • Moderator
  • Moderator
15 May 2020 14:45 #167848 by tommylight
Replied by tommylight on topic To get ping time shorter
No need if you have configured network through GUI.
15 May 2020 14:58 - 15 May 2020 15:00 #167849 by PCW
auto lo
auto enp0s25
iface enp0s25 inet static
address 10.10.10.11
Last edit: 15 May 2020 15:00 by PCW.
15 May 2020 14:59 #167851 by PCW
You cannot configure things like irq coalescing options via the GUI
  • Moderator
  • Moderator
15 May 2020 15:18 #167855 by tommylight
I said network, he already has coalescing where it belongs.
15 May 2020 15:28 #167856 by PCW
Hardware driver settings are per device so should be in the interfaces file
under the specific device (enp0s25 in this case) you are configuring,
so no, he did not have it set properly
15 May 2020 16:24 #167864 by Clive S
auto lo
auto enp0s25
address 10.10.10.11
I now have this in the file
auto lo
auto enp0s25
address 10.10.10.11
I also rebooted the pc. but not it did not bring the ping time down.
It does if I just put - sudo ethtool -C enp0s25 rx-usecs 0 -in a terminal but then it dose not save it upon reboot
15 May 2020 16:31 #167865 by PCW
It looks like the
hardware-irq-coalesce-rx-usecs 0
text is corrupted (wrong dash symbol)
Time to create page: 0.121 seconds
