problem for use remap
- mahdi2001h
18 Jun 2020 08:35 #171990
by mahdi2001h
problem for use remap was created by mahdi2001h
Hi
I tried to use remap for add my own G-code and run some python code by them
but when my CNC machine starting read G-codes just all remaped G-code run at start and not run in line that should run (but other lines run correctly)
for use remap I read linuxcnc.org/docs/html/remap/remap.html
my linuxcnc version is 2.7.15
I added this lines in my ini file :
and added in G-codes(inside other lines) :
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
REMAP=G70 modalgroup=1 argspec=Pq py=g700
REMAP=G70.1 modalgroup=1 argspec=Pq py=g701and added in G-codes(inside other lines) :
G70 P8
G70 P9
G70 P10
G70.1 P6regards
- Thank you received: 2164
18 Jun 2020 09:46 #171995
Replied by Aciera on topic problem for use remap
Could you also show your python code?
- mahdi2001h
18 Jun 2020 09:49 - 18 Jun 2020 09:49 #171996
by mahdi2001h
Replied by mahdi2001h on topic problem for use remap
def g700(self, **words):
s.poll()
if s.estop == 0:
print "test p =" , words["p"]
return INTERP_OK
def g701(self, **words):
s.poll()
if s.estop == 0:
print "test1"
return INTERP_OK
Last edit: 18 Jun 2020 09:49 by mahdi2001h.
- Thank you received: 4144
18 Jun 2020 09:50 #171997
Replied by rodw on topic problem for use remap
There is a Sim with remapping setup. Have you looked at it. It is helpful as none of it is intuitive...
- mahdi2001h
18 Jun 2020 09:53 - 18 Jun 2020 09:56 #171998
by mahdi2001h
where is that?!
How can I use it?
How can I use it?
Last edit: 18 Jun 2020 09:56 by mahdi2001h.
18 Jun 2020 10:00 #171999
From the main linuxcnc config chooser, there should be a whole list of simulations. One of them is called remap... so it will run without a machine and you can study how it works.
- mahdi2001h
18 Jun 2020 10:19 - 18 Jun 2020 10:20 #172000
by mahdi2001h
oow
I've seen this before
It didn't help me
Because it did the same
But I'm reviewing it now
thanks
It didn't help me
thanks
Last edit: 18 Jun 2020 10:20 by mahdi2001h.
18 Jun 2020 17:18 #172020
Ok I've only done remaps with python script once before. My INI contains this:
Then my config folder contains a folder called python and inside that folder lives my remap.py (contains my python scripts for g912 and g913), toplevel.py, oword.py, stdglue.py and util.py.
toplevel.py contains
oword.py contains:
stdglue.py is an empty file
util.py contains:
REMAP=G91.2 modalgroup=1 argspec=xyzabc python=g912
REMAP=G91.3 modalgroup=1 argspec=xyzabc python=g913Then my config folder contains a folder called python and inside that folder lives my remap.py (contains my python scripts for g912 and g913), toplevel.py, oword.py, stdglue.py and util.py.
import oword
import remapoword.py contains:
from util import call_pydevd
def foo(*args):
print "foo!"
# make debugger available as oword procedure
def pydevd(self,*args):
call_pydevd()
# this would be defined in the oword module
def mysub(self, *args):
print "number of parameters passed:", len(args)
for a in args:
print astdglue.py is an empty file
util.py contains:
import inspect
import emccanon
# O-word procedure to trap into the Pydevd debugger
# start debug server in Eclipse, then
# call as 'O<pydevd> call' from MDI
# example setup for debugging embedded Python code
# see http://pydev.org/manual_adv_remote_debugger.html
# if this points to a valid directory,
def call_pydevd():
""" trap into the pydevd debugger"""
import os,sys
pydevdir= '/home/mah/.eclipse/org.eclipse.platform_3.5.0_155965261/plugins/org.python.pydev.debug_2.0.0.2011040403/pysrc/'
# the 'emctask' module is present only in the milltask instance, otherwise both the UI and
# milltask would try to connect to the debug server.
if os.path.isdir(pydevdir) and 'emctask' in sys.builtin_module_names:
sys.path.append(pydevdir)
sys.path.insert(0,pydevdir)
try:
import pydevd
emccanon.MESSAGE("pydevd imported, connecting to Eclipse debug server...")
pydevd.settrace()
except:
emccanon.MESSAGE("no pydevd module found")
pass
def lineno():
""" return line number in the current Python script """
return inspect.currentframe().f_back.f_lineno
def error_stack(self):
""" print the Interpreters error stack (function names) """
print "error stack level=%d" % (self.stack_index)
for s in self.stack():
print "--'%s'" % (s)
def callstack(self):
""" print the O-Word call stack """
for i in range(self.call_level):
c = self.sub_context[i]
print "%d: pos=%d seq=%d filename=%s sub=%s" % (i,c.position, c.sequence_number,c.filename,c.subname)
The following user(s) said Thank You: mahdi2001h
- mahdi2001h
21 Jun 2020 05:45 #172220
by mahdi2001h
Please also send your remap.py file
21 Jun 2020 06:39 #172222
remap.py:
Warning: Spoiler!
import sys
import traceback
import numpy
#import pprint
from math import sin,cos,atan2,sqrt,pi,degrees
from interpreter import *
from emccanon import MESSAGE, SET_MOTION_OUTPUT_BIT, CLEAR_MOTION_OUTPUT_BIT,SET_AUX_OUTPUT_BIT,CLEAR_AUX_OUTPUT_BIT
from util import lineno, call_pydevd
throw_exceptions = 1 # raises InterpreterException if execute() or read() fail
#Remap for Incremental moves in tool coordinates "G91.2 x y z a b c
def g912(self, **words):
#genserkins.c uses Rot[X,Y,Z] fixed angles rotation also called XYZ-Tait-Bryan angles
#First rotation: "c"-rotation is equal to rotation around z = Z-world-axis
#Second rotation: "b"-rotation is equal to rotation around the y'-axis
# "a"-rotation is always equal to rotation around x'' = X-tool-axis
#requested increments
c = self.blocks[self.remap_level]
dx = c.x_number if c.x_flag else 0
dy = c.y_number if c.y_flag else 0
dz = c.z_number if c.z_flag else 0
da = c.a_number if c.a_flag else 0
db = c.b_number if c.b_flag else 0
dc = c.c_number if c.c_flag else 0
#current position and orientation
old_x = self.current_x
old_y = self.current_y
old_z = self.current_z
old_a = self.AA_current
old_b = self.BB_current
old_c = self.CC_current
#calculate terms for rotation matrices
sa = sin(old_a*(pi/180))
sb = sin(old_b*(pi/180))
sc = sin(old_c*(pi/180))
ca = cos(old_a*(pi/180))
cb = cos(old_b*(pi/180))
cc = cos(old_c*(pi/180))
sda = sin(da*(pi/180))
sdb = sin(db*(pi/180))
sdc = sin(dc*(pi/180))
cda = cos(da*(pi/180))
cdb = cos(db*(pi/180))
cdc = cos(dc*(pi/180))
#---Calculation of the new position---:
#This is used to calculate the new POSITION in world coordinates according to the
#requested incremental moves along the tool coordinate axis (G91.2 x y z ...)
#Transformation matrix for the kinematics used in genserkins
A = [[ cb*cc , sa*sb*cc - ca*sc , ca*sb*cc + sa*sc ],
[ cb*sc , sa*sb*sc + ca*cc , ca*sb*sc - sa*cc ],
[ -sb , sa*cb , ca*cb ]]
#requested move in vector form
Pd = [[ dx ],
[ dy ],
[ dz ]]
#A*Pd - matrix multiplication (the order is important! A*Pd != Pd*A)
#'import numpy' is required for this
P = [[sum(a*b for a,b in zip(A_row,Pd_col)) for Pd_col in zip(*Pd)] for A_row in A]
#position in world coordinates is the sum of the old position and the rotated increments
x_new = old_x + P[0][0]
y_new = old_y + P[1][0]
z_new = old_z + P[2][0]
#pp = pprint.PrettyPrinter(indent=4)
#pp.pprint(A)
#---Calculation of the new orientation---
#This is used to calculate the new ORIENTATION in world coordinates according to the
#requested incremental moves along the tool coordinate axis (G91.2 ... a b c)
#matrix for rotation by angle 'c' around z-axis
Rz = [[ cdc, -sdc, 0 ],
[ sdc, cdc, 0 ],
[ 0, 0 , 1 ]]
#matrix for rotation by angle 'b' around y-axis
Ry = [[ cdb , 0, sdb ],
[ 0 , 1, 0 ],
[-sdb , 0, cdb ]]
#matrix for rotation by angle 'a' around y-axis
Rx = [[ 1 , 0 , 0 ],
[ 0 , cda, -sda ],
[ 0 , sda, cda ]]
#--Incremental rotation in WORLD-coordinates--
#this rotates the Tool-center-point around the X-,Y-,Z-axis of the WORLD-coordinate-system
#Matrix multiplications Rx*Ry*Rz*A (starting from right to left)
#multiply Rz * A
A = [[sum(a*b for a,b in zip(Rz_row,A_col)) for A_col in zip(*A)] for Rz_row in Rz]
#multiply Ry * A
A = [[sum(a*b for a,b in zip(Ry_row,A_col)) for A_col in zip(*A)] for Ry_row in Ry]
#multiply Rx * A
A = [[sum(a*b for a,b in zip(Rx_row,A_col)) for A_col in zip(*A)] for Rx_row in Rx]
#--Incremental rotation in TOOL-coordinates--
#this rotates the Tool-center-point around the X-,Y-,Z-axis of the TOOL-coordinate-system
#Matrix multiplications A*Rx*Ry*Rz (starting from right to left)
#multiply Ry * Rz
C = [[sum(a*b for a,b in zip(Ry_row,Rz_col)) for Rz_col in zip(*Rz)] for Ry_row in Ry]
#multiply Rx * C
B = [[sum(a*b for a,b in zip(Rx_row,C_col)) for C_col in zip(*C)] for Rx_row in Rx]
#multiply A * B
A = [[sum(a*b for a,b in zip(A_row,B_col)) for B_col in zip(*
] for A_row in A]
#now the required numerical results of all the elements of the transformation matrix have
#been calculated and we can solve the equations for the required angles a,b,c
#calculate new Euler angles a,b,c
c_new_r = atan2((A[1][0]),A[0][0])
c_new = degrees(c_new_r)
b_new_r = atan2(-A[2][0],sqrt(A[2][1]*A[2][1]+A[2][2]*A[2][2]))
b_new = degrees(b_new_r)
a_new_r = atan2((A[2][1]),A[2][2])
a_new = degrees(a_new_r)
#print(x_new,y_new,z_new,a_new,b_new,c_new)
#send new coordinates as G0 move to LinuxCNC
self.execute("G0 X%f Y%f Z%f A%f B%f C%f" % (x_new,y_new,z_new,a_new,b_new,c_new),lineno())
return INTERP_OK
#Remap for Incremental xyz-moves in TOOL coordinates , and incremental abc-moves in WORLD - coordinates
#"G91.2 x y z a b c
def g913(self, **words):
Pd = [[ dx ],
[ dy ],
[ dz ]]
#pp.pprint(A)
[ sdc, cdc, 0 ],
[ 0, 0 , 1 ]]
[ 0 , 1, 0 ],
[-sdb , 0, cdb ]]
[ 0 , cda, -sda ],
[ 0 , sda, cda ]]
#multiply Rz * A
#multiply Ry * A
#multiply Rx * A
return INTERP_OK
import traceback
import numpy
#import pprint
Pd = [[ dx ],
[ dy ],
[ dz ]]
#pp.pprint(A)
[ sdc, cdc, 0 ],
[ 0, 0 , 1 ]]
[ 0 , 1, 0 ],
[-sdb , 0, cdb ]]
[ 0 , cda, -sda ],
[ 0 , sda, cda ]]
#multiply Rz * A
#multiply Ry * A
#multiply Rx * A
#multiply Ry * Rz
#multiply Rx * C
#multiply A * B
return INTERP_OK
#"G91.2 x y z a b c
Pd = [[ dx ],
[ dy ],
[ dz ]]
#pp.pprint(A)
[ sdc, cdc, 0 ],
[ 0, 0 , 1 ]]
[ 0 , 1, 0 ],
[-sdb , 0, cdb ]]
[ 0 , cda, -sda ],
[ 0 , sda, cda ]]
#multiply Rz * A
#multiply Ry * A
#multiply Rx * A
return INTERP_OK
